High Idle Problem Found Source...
Old Mar 22, 2008 | 03:25 PM
sublime_ac's Avatar
sublime_ac
Default High Idle Problem Found Source...
Thanks to a fellow HDForum member who went through this same problem with his streetglide I found the problem in a matter of a few minutes... There is an idle speed screw at about four o'clock on the throttle body. I pulled the air cleaner / backing plate off and sure enough the screw had been loctited at one time but was totally loose, I could spin it with my fingers from behind. I roller it back to the line where the loctite was and fired it up and the bike is running like it should...
So now a new question... How can I get this screw to stay in place?
Old Mar 22, 2008 | 03:27 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: High Idle Problem Found Source...
JB Weld?
Does it seem stripped out? If not, put a dab of blue loctite on it and be done.
Old Mar 22, 2008 | 03:34 PM
sublime_ac's Avatar
sublime_ac
If I just loctite it will be more than a dab
I am thinking I can get a jam nut on the back side of it... Seeing as there is a service bulletin on this I really don't want it to happen again.. I will be going by the Harley dealership later today and I am gonna ask them to see the TSB...
Old Mar 22, 2008 | 03:39 PM
UltraKla$$ic
Do you have the TSB #?
Old Mar 22, 2008 | 03:40 PM
eglidetrike1's Avatar
eglidetrike1
I think a little more lock tite and you should be good to go.
Old Mar 22, 2008 | 04:29 PM
mrsr71's Avatar
mrsr71
A dab of finger nail polish will do the trick
Old Mar 22, 2008 | 04:33 PM
Jim Dawson's Avatar
Jim Dawson
ORIGINAL: mrsr71
What color works best?
Old Mar 22, 2008 | 09:15 PM
sublime_ac's Avatar
sublime_ac
I didn't get the TSB, couldn't find a nut thin enough to get on there and not mess with adjustment, so I nice dose of loctite on her and I am back in business.
Old Mar 22, 2008 | 09:22 PM
Dalton's Avatar
Dalton
That is the IAC screw. I have had to adjust mine due to the tuner I am using. I did put a jam nut on the backside. It is an odball thread, cant remember exactly what it is but you can take it out and go to a good hardware and you will find what thread on to it. Take the nut to a grinder and thin it down, then thread it on. Works great.
Old Mar 22, 2008 | 09:29 PM
sewerat's Avatar
sewerat
green loctite will penetrate the threads to help lock it better
