is this normal
Old Apr 3, 2008 | 06:34 PM
bwr52678's Avatar
bwr52678
Default is this normal
have a 06 street glide. stalled on me today had new plugs put in today along with all fluids changed.it wouldpop though air cleaner once in a while just got it out of storage really only noticed it popping which is very slightly thats why i had plugs changed they said the old ones looked good.i only noticed it popping after i got gas at the speedway station and it has never quit like that before do you think i could have got bad gas i need some imput thanks
Old Apr 3, 2008 | 06:54 PM
dawg's Avatar
dawg
Default RE: is this normal
Just out of storage? How did you set it up for storage? Stabil, etc? I'd guess that is the issue and that once you get things going you'll be fine.
Old Apr 3, 2008 | 07:39 PM
g money's Avatar
g money
Account Retired
Could be the 8 degree versus the 25 degree injectors. Do you know what ones you have? Mine did the same even with the 25 degree injectors. Added a fuel management system and cleared all propblems.
Gary D.
Old Apr 3, 2008 | 07:40 PM
skltr's Avatar
skltr
Could be condensation in the fuel ............ after storage.
Old Apr 3, 2008 | 08:08 PM
choochoo's Avatar
choochoo
Depends on who you ask if it's normal or not.
Dealer, you'll probably get it's normal
Most people here will say no it's not.
Was it popping before you put it in storage, or can you remember back that far.
How long was it in storage?
If it was not then it is something you did since then.
Possibly got bad gas or it is the stabil or whatever you may have used to fog the
engine.
I would pull the plugs, wipe dry and clean, confirm correct gap and correct plugs.
If you believe you may have moisture in gas, add the correct amount of HEET for
a five gallon tank, slosh it around, let it set a few minutes then start it up.
Run it a little bit and give the HEET a chance to absorb and dissipate the moisture
in the fuel system.
When down to about 1/2 refuel with 91 octane from station you trust and add the
proper amount of fuel injector cleaner for a 5 gallon tank then run it awhile.
See if that clears it up.
Old Apr 3, 2008 | 08:23 PM
bwr52678's Avatar
bwr52678
i had it in storage for 5 months with fuel stabilizer in the tank. tank was 3/4 full when i got it out of storage the exhaust would stink really burn your eyes i ran that down to half tank then refilled with 92 octane at speedway ran 70 miles then it just stalled on me never done that before maybe i should suck out 80 to 90 percent of the gas and get new gas at a different station i just really find it odd especially on a bike that has been dynoed....
Old Apr 3, 2008 | 08:33 PM
dgriffith's Avatar
dgriffith
I would suggest you clean the idle air induction port. Take the air cleaner off and look in the intake at the 12 o'clock position. There is a port there that has a plunger that opens and closes, to control idle. With engine off,Spray with carb. cleaner,Then turnswitch on and off slowly. You will see the plunger move. Mine had a bad habit of sticking till got about 15,000 miles on it.
Old Apr 3, 2008 | 08:38 PM
BrokenRK's Avatar
BrokenRK
6th Gear
My 99 is doing that and I was told after the dealer checked it out that my head gaskets are bad. Who knows?????
Old Apr 3, 2008 | 11:38 PM
choochoo's Avatar
choochoo
Not likely, but have any good mechanic do a compression leakdown test.
If gaskets are indeed defective and leaking, it will show up with this test.
But it could also be rings or valves/ guides.
ORIGINAL: BrokenRK
Old Apr 4, 2008 | 12:06 AM
wydopn231's Avatar
wydopn231
Id drain the tank and put in some fresh fuel.Ive had same trouble out of bike that set out and got water into fuel.
