Fairing squeaks
Old Apr 26, 2008 | 07:54 AM
ELCID's Avatar
ELCID
5th Gear
Default Fairing squeaks
Hello, I am new to HDF. I ride a 2006 Eligtra Glide Standard, (FLHTI). and I have logged 16K on her since I purchased her new in Jan 06.Recently, I have discovered a fairing squeak comming from the left side. Both fairing brackets have been replaced, becaused they broke. But the noise continues! Hasanyone had the same problem/fixed????
ELCID.
Old Apr 26, 2008 | 11:13 AM
CRAMBONE's Avatar
CRAMBONE
Default RE: Fairing squeaks
are you sure it's not your windshield? grab it next time to see if shuts up.
Old Apr 26, 2008 | 05:39 PM
Dabaldone's Avatar
Dabaldone
Maybe this will help.
This may seem strange, but a while agoI had a squeak that I could swear was coming from my Roadglide fairing.
I checked the fairing brackets, the belt, every nut and bolt for tightness.
Couldn't find the problem. I checked the entire exhaust, even went as far as to revove all the heat shields looking for this annoying squeak.
Still couldn't find it.
Finally I realized that I had started using a mid grade gas of 89 octane.
I guess I'm a cheap bastard and didn't want tospend the extra money onhigh test.
This squeak was driving me crazy. It was only there when I accelerated hard and the bike was warm.
Put some 93 octane in it and the squeak went away completely.
It never knocked or pinged, just squeaked.
Squeak never came back.
Old Apr 26, 2008 | 09:25 PM
ELCID's Avatar
ELCID
5th Gear
OK,
I took a 200 mile ride today, and while riding, helf onto the windshield, thanks for the tim, but, it didn't stop that squesk! So, I turned up the stereo and lived with the noise untio I have more time to "diag" the problem. Thanks for your help.
Gordon
Old Apr 26, 2008 | 09:30 PM
ELCID's Avatar
ELCID
5th Gear
Second Message,
As you can read, I sure as hell, can't type. Let me try this again..., today, I took a 200 mile road trip. As you suggested, I held onto the windshield, but no luck. The noise continues. I guess I will do further "diag" when I get more time. I just turned up my stereo and ignored the noise.
Gordon
Old Apr 26, 2008 | 09:34 PM
ELCID's Avatar
ELCID
5th Gear
Your right, it does sound a bit of crazy, but what have I got to loose, except that damm squeak? And I too, checked every nut and bolt and found zip, nada, zero! Tomorrow, I'll fill up with 89. I will let you know.
Gordon
Old Apr 26, 2008 | 10:36 PM
hot77vette's Avatar
hot77vette
had a problem with a noise in my faring (i thought) turned out it was the gas cap door . try riding down the road when you here the noise put the palm of your hand on the gas cap door try it a few times if the noise goes away pm me repair instructions will follow!!!!!!!!!!!!!!!
Old Apr 26, 2008 | 10:46 PM
izzi's Avatar
izzi
mine does it. fairing brackets ok. squeaks while pulling on windshield. i'm starting to wonder if it's the clutch cable squeaking at the grommet in the fairing.
Old Apr 27, 2008 | 07:33 AM
ELCID's Avatar
ELCID
5th Gear
IZZI,
I too thought it was the clutch cable rubbing on the rubber grommit. I removed the outter fairing, ensured the cable was not touching anything, and still the noise continues. I think when the noise gets worse, I do more searching.
Gordon.
PS, nice bike you have there....
Old Apr 27, 2008 | 08:55 AM
Dabaldone's Avatar
Dabaldone
Hey Elcid
Just to be clear, the bike squeaked with mid grade 89.
It doesn't squeak with high test 93.
It also has alot less vibration, especially when I take off from a stop.
