multipin connector help
Old May 22, 2008 | 10:29 PM
belmac's Avatar
belmac
Default multipin connector help
i am trying to insert a wire into the radio harness the instructions said to undo the secondary lock. i 've read the service manual till my eyes crossed and it don't look anything like the one on the radio. so how do you insert a wire into it
Old May 23, 2008 | 06:23 AM
belmac's Avatar
belmac
Default RE: multipin connector help
anyone??????????
Old May 23, 2008 | 06:33 AM
howa's Avatar
howa
Harley uses several kinds of connectors. Determine what kind of connector it is, e.g., Deutsch connector, Amp multilock connector, etc. These two types of connectors have multiple pins. With the Amp connector, not all of the pins are necessarily used. You may need to go to your dealer, (or an after-market H-D repair facility) and order extra pins for the connector. They're only a few cents.
Find out which connector it is. Google Deutsch connector and Amp multi-lock connector for more information.
Old May 23, 2008 | 07:24 AM
EasternSP's Avatar
EasternSP
Ok, you have an 07 Ultra. I'm still a bit in the dark about what you are adding to the radio harness. Can you provide the item part number and the page in the service manual that you are looking at.
Old May 23, 2008 | 09:14 AM
Harleypingman's Avatar
Harleypingman
What year bike?
If you have the HD Service Manual, it will identify the brand and number of wires in the connector in a lengthy table of numbered connectors in the Appendix.
The "secondary lock" is typically the a plastic piece that fits over the end of the connector--usually a different color plastic than the connector itself--and provides the "front" of the connector that goes into the radio--for example, on the Base Audio Connector that was used on '05 and older models to plug into the back of the radio, was a 23 place AMP connector, and the secondary lock is red plastic.
The "other" lock is the tab that secures the individual wires (sockets/pin terminals at their ends) to the connector that is moved slightly using a pick tool to release the wire from the connector. To get to the individual wires the secondary lock is removed.
Old May 23, 2008 | 09:59 AM
belmac's Avatar
belmac
i am installing the buletooth module from harley, it has two wires that go into the 35pin multipin connector. a red wire goes into hole #4 which is empty and the black wire goes into 27. looking at the service manual on page b8. this don't look like the multipen connector thats on the radio
Old May 23, 2008 | 01:11 PM
belmac's Avatar
belmac
got it. thanks
Jimmy55TX
Audio Systems
Mar 31, 2017 10:59 PM
Gitarded
Audio Systems
Apr 26, 2016 10:51 AM
Bo Joe
Mar 30, 2013 10:35 PM
Hashash
Oct 13, 2010 02:21 PM
jgcable
May 16, 2010 06:19 PM
