i need answers
i have a nighttrain with a stock motor seaircleaner and powercomander bassanni pro streets and im extremely satisfied. however...i just purchased a 06 electra glide standard had them put on semufflers seaircleaner and download..im not impressed... bike stalled on me sitting at a light twice the first day i rode it.the dealer installed the 1450 download should they of installed the 1550 download?
Looks like they are gonna change out the injectors on the bikes that are running poorly on initial cold starts. See it here:
http://mysite.wanadoo-members.co.uk/hhlair1/M1185.pdf
ORIGINAL: thebigbuckster
Take it back and be firm.
1 Post
Ditto.
ORIGINAL: terryt1955
If they installed the POS HD download then there is no use in wasting your money with a dyno because there are no adjustments. You are running extremely lean. Talk to them about the Harley Bulletin in reference to the SE Injectors being installed on 06's with your problems. Probably the only way you are going to make it run right is to install a SERT or PCIII and have it dyno tuned then so they can make the adjustments that are needed to get your bike to run right. I can't believe there are still dealers out there installing the POS download knowing that it just doens't work.
