08 FLHX white smoke and sluggish.. please help
i have an 08 flhx, i put vance and hinse true duals with the oval slip ons, and the screamin eagle cone mass air intake..... my question is my bike is very sluggish, and at the stop light white smoke comes out and it smells pretty bad..... does anybody have any ideas of what this could be? i appreciate the help..
RE: 08 FLHX white smoke and sluggish.. please help
Yes, the pipes are fine without the SERT or remapping.
BUT! You put that air intake on and you're prob getting too much air. You canot change the air cleaner without remapping!
They look cool, but they also change things and have a function. Put the stock air cleaner back on and you'll prob be ok.
Good luck!
Good luck!
The fuel pack does what the downloads do, so yes, it should work.
If I were you and you really want to keep that air filter, then I would just go ahead and get the stage 1. You're 2/3rds the way there already and you'll get increased performance.
ORIGINAL: mxmisfit
okay now will the vance and hinse fuel pack work for that or do i need to go get the down loads from the dealer? thanks
Put your $$$ on a FUEL-MANAGEMENT SYSTEM (V&\\;\\\\\\;H FuelPak - SERT - PCIII or ??)
I agree with the above but the smoke and "bad smell" is a concern. \\; Running an engine lean means too little fuel/too much air. \\; That causes high temps in the combustion chamber that could lead to a burnt valve or piston. \\; Light blue smoke is oil, black smoke is too much fuel. \\; Have the dealer do a leak down test to check your valve train.
ORIGINAL: SoCal_Pappy
DON'T waiste your $$$$ on a Dealer Stage 1 Download - They are still required to adjust your '08 to meet EPA STANDARDS and that means they will be adjusting it LEAN....
Put your $$$ on a FUEL-MANAGEMENT SYSTEM (V&\\;\\\\\\;\\\\\\\\\\\\\\;H FuelPak - SERT - PCIII or ??)
ORIGINAL: mxmisfit
BUT!
Stage 1 won't affect warranty issues.
Just sayin'
