cluth adjustment question
Old Jun 21, 2008 | 07:00 PM
ms3300's Avatar
ms3300
Default cluth adjustment question
Do I have to adjust the clutch if the space at the lever is within specs (the width of a dime)?&nbsp\\; I am doing my 5000 service on my 08 and don't wanna mess with it unless necessary.&nbsp\\; Also can I adjust the clutch basket w/o adjusting the cable or vice versa?&nbsp\\; thanx
Old Jun 21, 2008 | 07:06 PM
07RoadHawg's Avatar
07RoadHawg
Default RE: cluth adjustment question
You should only need to adjust the clutch if you feel slipping when you are accelerating and not&nbsp\\;touching the lever.&nbsp\\;\\\\\\; The free play on the handle bar end should be adjusted with the cable adjuster.&nbsp\\;\\\\\\; If you are adjusting the clutch in the primary, service manual says adjust cable to full slack.&nbsp\\;\\\\\\; So short answer is you can adjust cable and not clutch, but not clutch without cable.
Old Jun 21, 2008 | 07:27 PM
ms3300's Avatar
ms3300
thank you matrix.&nbsp\\; i appreciate your qucik response
Old Jun 21, 2008 | 07:32 PM
Point Man's Avatar
Point Man
Don't be afraid to adjust the clutch from the basket. It's very easy to do. Just follow what the manual says. I did it successfully after adjusting the cable didn't do the trick after 18K on the bike.
Took me about 15 min., taking my time. If I can do it, anyone can do it. Why pay a mechanic to do it if not neccessary!
jf7689
EVO
11
Oct 23, 2017 04:13 AM
Mfd6049
Apr 8, 2014 09:36 PM
Nute
Sep 10, 2013 07:11 PM
ajay450
Dec 28, 2010 04:33 PM
hoethree
Jul 7, 2010 08:26 PM
