Engine temp
Old Jun 22, 2008 | 03:39 PM
06Roadglider's Avatar
06Roadglider
Default Engine temp
Can some of you guy's tell me what temp your engine runs at when out on hwy as well as around town. What is a&nbsp\\;high temp on these V Twins.
thanks for your reply's
Old Jun 22, 2008 | 04:29 PM
rjmac53's Avatar
rjmac53
Default RE: Engine temp
230...
Old Jun 22, 2008 | 05:19 PM
iclick's Avatar
iclick
In these 90° days, my oil temperature peaks around 200° as long as I'm moving greater than 45mph, a bit higher moving slower. It has maxed out at 230° several times in heavy traffic during hot weather, but has never exceeded that temperature. I have an oil cooler, which helps control peak oil temperatures, reducing them probably 20-25°. Synthetic oil will make a smaller difference, perhaps 5-10°. The fairing lowers help with cooling at speed by channeling air toward the engine and creating a vacuum behind it to exhaust the hot air, but they also hurt cooling when not moving by trapping the air.
Old Jun 22, 2008 | 05:22 PM
SoCal_Pappy's Avatar
SoCal_Pappy
depends on AIR temp &amp\\; what Oil your using....&nbsp\\; Normal this ime of year in the So Cal Desert Areas &nbsp\\; 200 - 230&nbsp\\; (last year seen a couple of 250 at times)
Old Jun 22, 2008 | 05:24 PM
rbabos's Avatar
rbabos
Stock, my softail used to run 230 on highway and 250+ in town. Now with Tmax it's 200-210 highway and around 230-240 in traffic. Gauge has been tested for accuracy.
Ron
Old Jun 22, 2008 | 05:49 PM
06Roadglider
My reason for asking is with just the standard map downloaded from the cert pick maps my engine was running around 180 well moving. Now that I have dyno map it runs around 260. This is what I am getting when I do a data log with lap top. should I be concerned???
Old Jun 22, 2008 | 09:39 PM
dog116929's Avatar
dog116929
I have just made a post with the same questin as yours.&nbsp\\; I got my bike out of the shop Friday and today the temp reached 260, my first reaction is that the timing has been set incorrectly.&nbsp\\; I never reached anything over 230 on a normal day before the dyno.
Old Jun 22, 2008 | 10:01 PM
Harleypingman's Avatar
Harleypingman
If you have already posted oil temps, please specify if it's an oil temp gauge in the diptstick, oil temp sending unit in the oil pan, etc.
&nbsp\\;
As for running hotter after a dyno tune v. pre-dyno tune, the higher temp is probably a function of leaning the mixture to get a more complete burn of the fuel.&nbsp\\;&nbsp\\; One of the consequences of a richer mixture/less timing, is the unburned fuel cools the combustion chamber.
&nbsp\\;
Also, the SERT data log&nbsp\\;measures&nbsp\\;engine temps, not oil temp.
Old Jun 23, 2008 | 12:14 AM
poppa cooter's Avatar
poppa cooter
youre probably reading the head temp on your laptop not the oil temp. head temp 260 is normal for head temp, i have a thundermax tuner and by default my check engine light wont come on until the heads reach 300.
Old Jun 23, 2008 | 12:37 AM
06Roadglider
yes I am awhere that the cert would read the engine or head temp. Maybe my post was not clear but I think I was talking engine not oil...lol
Thanks for your reply
