hands
Old Jul 16, 2008 | 07:25 AM
cycletrash98's Avatar
cycletrash98
Default hands
Anyone have tips for what to do about sore hands while riding? I Have a new 08 ultra and the outside of hands get extremely sore when riding.
Old Jul 16, 2008 | 07:35 AM
honestbob's Avatar
honestbob
Default RE: hands
let them hang(one at a time) and wiggle your fingers, gets the blood flowing. Try to grip a little lighter when riding and they won't get as sore.
Old Jul 16, 2008 | 07:41 AM
Windup08's Avatar
Windup08
Default RE: hands
Try not to grip too tight, relax a little. As mentioned shake them out once in awhile. I also found that going to a larger size grip helps although I didn't have the same problem you have, my problem was that my thumb and index finger would start going numb.
Old Jul 16, 2008 | 08:13 AM
omgtkk's Avatar
omgtkk
Default RE: hands
Try switching to Kuryakyn Iso-Grips with the throttle boss.&nbsp\\; That will give you a larger diameter grip and the throttle is a place to rest the heel of your hand.&nbsp\\; They also do a good job of absorbing vibration that tranmits through the bars.&nbsp\\; Installation is an easy do-it-yourself.
Old Jul 16, 2008 | 08:20 AM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: hands
Quit gripping the bars so tight.
Change out the JUNK OEM grips for ISO Grips.
Change out the Handlebars to fit your riding style better.
Always wear gel pack gloves
Old Jul 16, 2008 | 08:46 AM
chiefparry's Avatar
chiefparry
Default RE: hands
+ 1...will also reduce the most handgrip vibration as well.
&nbsp\\;
ORIGINAL: omgtkk
Try switching to Kuryakyn Iso-Grips with the throttle boss.&nbsp\\;\\\\\\; That will give you a larger diameter grip and the throttle is a place to rest the heel of your hand.&nbsp\\;\\\\\\; They also do a good job of absorbing vibration that tranmits through the bars.&nbsp\\;\\\\\\; Installation is an easy do-it-yourself.
Old Jul 16, 2008 | 09:25 AM
blkfalc4's Avatar
blkfalc4
Default RE: hands
&nbsp\\;LOL Get more practice in the bathrm when not riding&nbsp\\; [:-]
Old Jul 16, 2008 | 09:29 AM
AtkRWC's Avatar
AtkRWC
Default RE: hands
ISO Grips and Padded gloves.&nbsp\\; Us the Cruise Control when possible.
Old Jul 16, 2008 | 09:39 AM
Amodump001's Avatar
Amodump001
Default RE: hands
The above suggestions will work. On other bikes you find that you can push them around through corners and such. You can’t do that on the larger heaver bikes. Practice your driving skills and try to relax more. &nbsp\\;
Old Jul 16, 2008 | 09:50 AM
roadkingrick's Avatar
roadkingrick
Default RE: hands
