uneven mufflers
My ultra pipes are uneven also. \\; Left is lower then the right. \\; I noticed it when I put down swept tips on my SEII's. \\; I have tried to move the left up but can not. \\; Also had Harley try to even them out. \\; They could not do it either. \\; When you have this problem you check other baggers. \\; There are many out there the same way. \\; Left hard bag is also lower.
ORIGINAL: TheBagger
Hey if you need two rubbers to keep your pipe tight....
LMFAO!!!!!!!! good one
ORIGINAL: stoker62
It's true that the right side muffler likes to move..especially if you have a 2 into 1 and a non stock engine and you ride more than 3 miles a week at over 20 miles an hour. \\;\\\\\\;\\\\\\\\\\\\\\; but if your bike stays in a climate controlled shrine \\;\\\\\\;\\\\\\\\\\\\\\; until that sunny sunday when you carefully back it out for all the neighbors to see what a bad to bone guy you are dressed to the hilt in the latest harley fashion gently dusting it off ...well i guess you don't have to worry about the muffler oh so ever slightly moving. I think i'm going to try that 2 rubber trick. \\;\\\\\\;\\\\\\\\\\\\\\; cuz 2 rubbers have to be better than one.
valleyrider
Aug 20, 2009 01:52 PM
