grip change problem
Old Jul 29, 2008 | 08:00 PM
flight's Avatar
flight
Default grip change problem
I went to change the grips on my 2008 street glide.&nbsp\\; It has the fly by wire throttle and the directions state that you may have to give it a " slight tug" when i gave it a slight tug i ended up with the whole f*&amp\\;^#en throttle assembly in my hand and unpluged from the internal wiring in the handle bar.&nbsp\\; Anyone else have this problem?? besides taking it to the stealer is there an easy way to fix this???
Old Jul 29, 2008 | 08:40 PM
omgtkk's Avatar
omgtkk
Default RE: grip change problem
Ouch! No Easy way. You'll have to remove the fairing and find the connector for the FBW harness. Disconnect it and thread the other end through so you can reconnect the green connector. Maybe an hours work
Old Jul 29, 2008 | 08:43 PM
dawg's Avatar
dawg
Make sure you didn't break the green connector. Continued next post cuz of forum problems[:@]
Old Jul 29, 2008 | 08:44 PM
dawg's Avatar
dawg
Easiest way is to pop ignition and take off lower inner fairing and pull wire out of bottom of bar.
Old Jul 29, 2008 | 08:45 PM
dawg's Avatar
dawg
Check green clip for damage and if not damaged tape a wire to it and feed wire back up bar till comes out end.
Old Jul 29, 2008 | 08:50 PM
flight's Avatar
flight
what is the little black wire??&nbsp\\; there is a green conector and a black wire
Old Jul 29, 2008 | 08:54 PM
dawg's Avatar
dawg
black wire is like an antenna or something, should be a floppy rubber short piece.
Old Jul 29, 2008 | 09:01 PM
EasternSP's Avatar
EasternSP
Geez guy, was this like, one foot on the tank while leaning way back pulling on the throttle?
Old Aug 11, 2008 | 06:24 PM
JJAA's Avatar
JJAA
Question
Originally Posted by flight
I went to change the grips on my 2008 street glide. It has the fly by wire throttle and the directions state that you may have to give it a " slight tug" when i gave it a slight tug i ended up with the whole f*^#en throttle assembly in my hand and unpluged from the internal wiring in the handle bar. Anyone else have this problem?? besides taking it to the stealer is there an easy way to fix this???
Hello,
I've ordered Kuryakyn Iso 6228 for my 2008 King, and
I'd like to avoid this risk
Would cutting of the stock rubber to remove it help ?
Thanks for any tip,
Old Aug 11, 2008 | 06:29 PM
TheGlide's Avatar
TheGlide
I changed my grips, I had to cut the left one off, and the right one slipped off, went together easy too, I musta got an easy one!?
