chrome fork question
Old Jul 31, 2008 | 08:33 PM
NightTrain05's Avatar
NightTrain05
4th Gear
Default chrome fork question
For those of you that have installed them on your own, what did you use to install the oil seals? Thanks
Old Jul 31, 2008 | 08:34 PM
dawg's Avatar
dawg
Default RE: chrome fork question
PVC pipe
[IMG]local://upfiles/13641/2AC5EA0B68164F5389088625F73BE670.jpg[/IMG]
[IMG]local://upfiles/13641/6855E500AF914C87BF389F37EA65DFDE.jpg[/IMG]
Old Jul 31, 2008 | 08:43 PM
NightTrain05
4th Gear
I was hoping that would work. Thanks a ton for the quick response.
Old Aug 1, 2008 | 04:33 AM
NightTrain05
4th Gear
One more question, can I reuse my stock fork bushings or do they press in? This is on a 08 EGC. I have to make a run to the HD dealer tonight and I want to be sure that I have everything for tomorrow's install. Thanks.
Old Aug 1, 2008 | 06:21 AM
dawg's Avatar
dawg
Change the seals and the copper washers on the 6mm bolts (or just get new bolts as the come with washers) The rest should be fine
Old Aug 1, 2008 | 08:14 AM
im's Avatar
im
really good idea to purchase extra 6mm bolts...those bolts are difficult to remove sometimes...may wish to use some pb blaster and let sit ...and then impact wrench....
Old Aug 1, 2008 | 10:24 AM
NightTrain05
4th Gear
Do the bushings press into the fork sliders, or do they stay wrapped around&nbsp\\;the fork tubes when I take the front end apart? The manual really doesn't do a good job of explaining that. Thanks
Old Aug 1, 2008 | 10:34 AM
dawg's Avatar
dawg
I have pics on here somewhere of when I took mine apart. None of them are "pressed" on.
Old Aug 1, 2008 | 10:37 AM
dawg's Avatar
dawg
LINK to mine
Old Aug 1, 2008 | 10:51 AM
ezlife's Avatar
ezlife
Real easy.Did mine about 6 mnths ago and used Dawg's 1.5" pvc idea (2' long). Worked great.Make sure retainer clip seats fully all around in groove, seal has to be fully seated to happen.
