Stereo Upgraded
Old Aug 4, 2008 | 09:10 PM
Abnmarine's Avatar
Abnmarine
Default Stereo Upgraded
This past weekend I removed my HD radio and installed a Sony CDX GT-720 head unit with Sirius radio, a Blaupunkt THA275PNP 75W x 2 amplifier, and 4 Polk Momo MMC 525 5-1/4" 2-way speakers. I used the Hawg Wired installation kit and adapter harness to retain the handlebar controls.
Abnmarine's Avatar
Abnmarine
Default RE: Stereo Upgraded
My previous system was Hogtune front and rear speakers with their amp. It sounded pretty good but I wanted satellite radio and a Sony unit so I removed the whole system.
Abnmarine's Avatar
Abnmarine
The amp is a 2 channel amp. I was limited with space since I installed everything under the fairing. That is why I didn't go with a 4 channel amp. I wired the speakers so that the amp runs in a 2 ohm load. It is rated to handle this.
Old Aug 4, 2008 | 09:18 PM
White Knight 04's Avatar
White Knight 04
Must have had no use for a C.B. huh???
Old Aug 4, 2008 | 09:30 PM
Abnmarine's Avatar
Abnmarine
The system rocks! I use 1/2 of the volume as before and it is very clean and plenty loud. The speakers came with their own crossovers
Abnmarine's Avatar
Abnmarine
Only bad part is that I didn't take any photos of the install prior to putting the fairing back on.
mrbuck's Avatar
mrbuck
good luck with that amp i had two and both would cut out once volume went past about 3/4 doa search others had same problem, hope you dont
&nbsp\\;
Old Aug 4, 2008 | 09:31 PM
Abnmarine's Avatar
Abnmarine
Just wanted those of you tossing the idea to know that there are better systems out there that are cheaper.&nbsp\\;
Abnmarine's Avatar
Abnmarine
I'm totally satisfied with my choices.
Abnmarine's Avatar
Abnmarine
Well at least our post count increases with the forum problems.
