Need your knowledge.
Old Sep 6, 2008 | 09:33 PM
ToadsUltra07's Avatar
ToadsUltra07
Default Need your knowledge.
Subject --> Speedometer
This is what is happening.
The speedometer no matter what gear I am in, or what speed I am going, it has a flutter too it. Sometimes a very small bounce in reading the speed. It bounces, flutters an average of 3 to 4 miles per hour while showing the speed... This is the best description I can give to what it is doing.
Here is where I need your knowledge. Has this happened to your bike? If so, what did you do to fix it?
Please keep in mind this is a 2007 Ultra Classic, there is no speed cable leading to the spedometer on this bike..
Thanks,
ToadsUltra07
Old Sep 6, 2008 | 09:45 PM
2deuce's Avatar
2deuce
You could be having a problem with the speed sensor.
The other thing I've heard is that the electronics start acting funny if you shut the bike down by just turning off the ignition switch and not using the kill switch first.
Old Sep 6, 2008 | 10:51 PM
hogdoctor's Avatar
hogdoctor
pull your speed sensor out of the transmission and clean any metal filings off of it, and try it again.
Hogdoctor
Old Sep 6, 2008 | 10:53 PM
Zimbob's Avatar
Zimbob
Does sound like a speed sensor going bad or dirty.
Old Sep 7, 2008 | 03:22 AM
GT_RoadGlide's Avatar
GT_RoadGlide
I had the same problem with my 00 Sporty. The sensor is a magnetic pickup, so the small magnet will attract ferrous material. In my case the wires going into the assembly were broken.
Old Sep 11, 2008 | 03:51 PM
ToadsUltra07
Default Thank you, Fixed the Problem
Took the speed sensor out. It indeed have some ferris material around the magnetic unit.
Cleaned it off, replaced the seal with a new one, and put it back in.
Took it for a test spin, and no more flutter, and bounce on the speedometer.
Again, Thank you for responding.
Would have done it sooner, but just gotten home last night from the hospital, had some surgery.
Thanks Again,
ToadsUltra07
Old Sep 12, 2008 | 09:15 AM
BezerkoBob's Avatar
BezerkoBob
Speedometer? What's that for?
Old Sep 12, 2008 | 12:28 PM
katobird's Avatar
katobird
Speedometer is directly connected to the Air guage.
Mine has a red LED in the air guage also.
LED red light comes on warning of beer low level and Speedo tells me how fast I should be going to get there.
Brook Allen
Aug 13, 2013 05:20 PM
redrunner
Jul 22, 2013 07:00 PM
pmcburne
Jul 3, 2013 07:03 PM
kittery
Jul 13, 2010 05:02 PM
Zeroqll
Sep 24, 2009 05:22 PM
