Electrical problem solved
Old Sep 7, 2008 | 06:54 PM
harley-jones's Avatar
harley-jones
Default Electrical problem solved
I am posting this to maybe help someone out if this ever happens to them!
I have had a rather perplexing problem with my 08 SG. The bike would run fine while on the road, but if I started it up on the side stand it would start right up and then the battery light, engine light, security key light and the ABS light would light up solid and stay on.
I finally figured it out. It had to do with the handle bars being turned full left was causing the problem. Turn them straight or to the right and all was well.
I took the outer fairing off and found one of the bundles of wires was up against the sharp corner on the Heat Sink on the HK radio. It had worn a small hole through the protective sheath and was into one of the wires inside and was grounding out. I put a piece of shrink tubing on the wire, moved them away from the sharp corner and all is fixed.
If I would just climb on and center the bars and start off it was fine. I had it in my head that something was wrong with the ECM because it would not happen all the time.
This took me a while to figure out what was going on. I hope this helps someone else out.
Old Sep 7, 2008 | 07:27 PM
Trock's Avatar
Trock
Sure nice when things go right isn't it? Sometime electrical problems are the worse too. Glad all is well.
Old Sep 8, 2008 | 03:29 AM
GT_RoadGlide's Avatar
GT_RoadGlide
I had the same problem with 2000 1200C Sporty. Turn bars full left after I turned key off. Put key in and turn on before I got on and started bike. The instant I turned the key on I blew a fuse. A sharp edge on wind shield mount pierced wiring harness when bar turned full left. Took care of the sharp edge and electrical tape to cover pierced wire. No more problem. Took a week and a few fuses to find.
Old Sep 8, 2008 | 10:13 AM
gmc's Avatar
gmc
Can happen also if your handlebar grips clamp isn't tight enough and it slides back. It will pinch the wires which have to be tucked in the groove. Intermitant problem blowing fuses but then OK when got running and hot. I thought it was a relay because sometimes would pull those and it would stop blowing fuses but found out fr tech that a relay won't blow a fuse.
Old Sep 8, 2008 | 10:45 AM
jsimo7's Avatar
jsimo7
I had a similar problem with a 99 Ultra
rgrecco
Sep 21, 2017 09:04 AM
Booey424
Mar 28, 2012 04:30 PM
UncleChey
Electrical/Lighting/Alarm
Feb 14, 2011 04:31 PM
neverdown
May 21, 2010 05:30 AM
Dagerazod
Jan 10, 2009 12:35 PM
