wind shield threaded inserts
Old Oct 1, 2008 | 08:10 AM
patsac's Avatar
patsac
Default wind shield threaded inserts
fyi
just replaced 1 of my inserts with the new threaded style. i ran a 3/8" tap in first to help it get started ,but, i should have used a bottoming tap because as i ran out on threads the tabs on the new insert snapped off. befor i replace the other 2 im off to get a bottoming tap
Old Oct 1, 2008 | 08:12 AM
harley-jones's Avatar
harley-jones
Good advise, Thanks!
Old Oct 1, 2008 | 08:14 AM
n8dc's Avatar
n8dc
Got a bench grinder ? make a bottom tap.
Dave
Old Oct 1, 2008 | 09:28 AM
Edgeflhtci's Avatar
Edgeflhtci
6th Gear
Originally Posted by patsac
fyi
Bottom tap is the way to go...If I'm not mistaken though the inserts should be installed so that the slotted side goes in first. That's the way I did it anyway. After I tapped the holes, I threaded the brass inserts on to the bolts and used them to install the new inserts.
Edge
Old Oct 1, 2008 | 09:42 AM
HarleyWood's Avatar
HarleyWood
Edge
That is correct. The slotted end goes in first to aid in thread cutting, although a bottom tap makes the process a lot easier. thread the insert on to a 1/4-20 bolt with a lock nut to install. Use a drop of red loctite or super glue on the outer threads of the brass insert.
Old Oct 1, 2008 | 09:50 AM
rideon's Avatar
rideon
The slotted end definitly goes in first, lock tight should not be used on plastic because it will destroy it. Once the inserts are installed they won't back out and are a great fix.
Old Oct 1, 2008 | 10:07 AM
patsac's Avatar
patsac
dang, and i thought that the slotted end was for a screwdriver to thread them in.
oh well. the 1 i put in backwards holds ok but the next 2 will go in right.
learn something new every day
thanks guys
Old Oct 1, 2008 | 11:06 AM
drbillk's Avatar
drbillk
Hmmmm... seems to me that the slotted end would be for the screwdriver, otherwise, what purpose would they serve?
Old Oct 1, 2008 | 11:32 AM
mariner227's Avatar
mariner227
The part number for the new inserts is 16585-96. The slots are not made for a screw driver. The slots go into the fairing. There is no need to use a tap first. Lock tite will have a bad effect on the plastic.
Old Oct 1, 2008 | 11:49 AM
Edgeflhtci's Avatar
Edgeflhtci
6th Gear
In the grand scheme a tap isn't truly needed. It's just one of those tools that make the job at hand easier to deal with. Tapping the hole first relieves the amount of torque you would otherwise place on the mounts. Being that they are plastic, they will snap off and then you have new problem to deal with ;-)
Edge
