sert diy
Old Oct 17, 2008 | 08:52 AM
sugarbear's Avatar
sugarbear
Default sert diy
Has anyone installed a sert themselves? How user friendly is it for a person with average computer skills? Are there any other options for an '09 yet?
Old Oct 17, 2008 | 09:24 AM
Harleypingman's Avatar
Harleypingman
The SERT is simply a device to communicate between the bike's ECM (to change fuel and ignition timing primarily) and a computer (that is the source of the new mapping information for the ECM). So a SERT isn't really "installed" on a bike--it's simply the device that allows the ECM's fuel management settings to be changed.
Check out the TTS Master Tune. It's made by the company that previouslly provided the SERT to HD until this year. Looks like an excellent product.
And yes, a person with decent computer skills can use a SERT. It's not difficult to hook up the computer, SERT, and cables to load HD's (or TTS') canned maps.
Another excellent product is the DTT Twin Scan II+ with WEG0. Basically, it's a device to measure and record afr and transport the data to a computer for establishing accurate information for tuning with a SERT.
I have a SERT and have tuned my bike using it, my laptop, and the DTT TSII+ and WEGO--nothing fancy performance-wise on my bike; just some Rinehart TD's, SE a/c, and Head-Quarters HQ-0034 bolt-in cams.
Old Oct 17, 2008 | 09:26 AM
aclass's Avatar
aclass
No problem installing, putting the "canned" tune in will help but to really take advantage you ought to consider having a good tuner dial it in. I was quite impressed at the difference once I had my bike tuned.
Old Oct 17, 2008 | 09:41 AM
bigskyhd's Avatar
bigskyhd
I'd be reluctant to try it, but I'm sure your computer skills are much great than mine. That said, If you're still going to need someone to do the fine tuning, (to get the max out of it) perhaps it's just as easy to have the entire thing done all at once. Just an opinion..
Old Oct 17, 2008 | 10:09 AM
sugarbear's Avatar
sugarbear
When I get thru with it I will have it dynoed but in the meantime I will add things one at a time. I just want to make the minor changes until I complete the whole package
Old Oct 17, 2008 | 10:19 AM
Chula's Avatar
Chula
What is the whole package?
Old Oct 17, 2008 | 11:15 AM
04harleyboy's Avatar
04harleyboy
Piece of cake to install, and set up. Canned map gets you close, dyno gets you right on.
Old Oct 17, 2008 | 11:20 AM
sugarbear's Avatar
sugarbear
Big Bore kit heads and cams but I will probably do pipes and intake first
Old Oct 17, 2008 | 11:58 AM
klemay's Avatar
klemay
If you plan to "DIY" with a SERT, where does one get the software??
Old Oct 17, 2008 | 01:51 PM
sugarbear's Avatar
sugarbear
The software comes with the sert. I understand you have to buy a additional cd for the '09
