Accessory Circuit Help
Old Oct 28, 2008 | 02:30 PM
up2nogood22's Avatar
up2nogood22
Thanks for the replies to all. It appears that there are two identical connectors, the one I am using is what is listed in the owners manual as the accessory connector but apparently there is another 4 pin Deutsch hidden in there somewhere, I will look tonight.
I see the two different ones in the schematic now, one 4 wire and one 3 wire.
Not sure yet what the 4 pin Deutsch I am using is intended for, but will find out!
Old Oct 28, 2008 | 08:28 PM
Potato_Potato's Avatar
Potato_Potato
I have been wondering that too. My accessory plug is under the seat but the Owners Manual incorrectly shows it under the left side cover. There are 2 under the left side cover - one is the data port - does anyone know what the other one is?
Old Oct 29, 2008 | 04:59 AM
up2nogood22
I am not sure what it is for, but I know it provides an ignition switched +12V on pin 4!!
Old Nov 24, 2008 | 02:05 PM
JoeSwiatek's Avatar
JoeSwiatek
Originally Posted by up2nogood22
Anyone?
I believe you are looking at the data connector. I made the same mistake. In the owners manual for my 2008 Ultra there is a photo identifying the data connector as the accessory connector! grrrr.....
Old Nov 24, 2008 | 03:12 PM
2005UltraNC's Avatar
2005UltraNC
What ya want to switch? Would be carefull what size current draw you put off the Acc switch. I put a relay off the Acc switch to switch my heating gloves on/off.
Old Nov 24, 2008 | 09:30 PM
HawgriderPa's Avatar
HawgriderPa
definately would not wire the moto lights thru the accessory switch, unless you're using the relay harness for them. They draw too much wattage.
harness connects directly to the battery with a relay.. relay is wired into the accessory switch. when on, it engages the realy and the lamps draw directly from the battery.
Have 3 harnesses on mine for the lights, nother relay one for the air horn. and a heated clothing harness is also on the battery - connector for the thermostat sticks out the side under the seat.
no high wattage goes thru my switches
Old Jan 10, 2009 | 07:06 AM
IndyRider's Avatar
IndyRider
According to my 2006 RK service manual the accessory plug and circuit is rated at 15 amps max. I would think that includes the switch also.
Gerbing gloves only draw 2.2 amps and the jacket liner 6.4 amps so it should be well able to handle both of them with a total of 8.6 amps.
Old Jan 10, 2009 | 07:30 AM
Heathen's Avatar
Heathen
Originally Posted by rocknrod
The one with the cap on it is the acc plug.
Now thats how to answer a question !
FLYSBY
Electrical/Lighting/Alarm
Mar 3, 2013 03:37 PM
capt_caveman
Mar 27, 2011 09:56 PM
rcdifalco
May 28, 2010 09:14 PM
81fxb
Aug 6, 2008 05:16 PM
RonH
Jan 21, 2008 04:32 PM
