GPS Query
Zumo 450 for $350 at Costco
The 450 is identical to the 550 except:
(1) No XM or bluetooth capability.
(2) Does not speak street names, e.g. "In 500 ft., turn right ON ELM STREET." Instead, it will say "In 500 ft., turn right."
(3) Does not have a car mount in the package.
1) Advanced Audio Nav System at 800$ , worth it ? Pros/Cons
2) Road Tech Zumo also 800$ , worth it ? Pros/Cons
I realize the "worth it" is merely subjective
3) something else ??
4) Seems I saw somewhere here where stealers can be flashed into the Zumo's from a source other than Harley
2. Road Tech Zumo, no. Zumo 550 from Garmin, definitely worth it & available for well below that $800. Pros....... No real need for maps. Very comprehensive database of phones & addresses for where ever you are, at your fingertips. Wired to your intercom, or via bluetooth, voice directions for routing. Access to your bluetooth cell phone if you want. An additional fuel gauge that will remind you to get fuel & then show you gas stations from nearest to furthest. The ability to find hospitals, restaurants, hotels, repair services, shopping, amusements, businesses, friends homes, whatever you need, without calling for directions. Having all that information without needing to carry an atlas & steal a phone directory is well worth the cost.
Cons......???
Worth it? If you travel........Priceless! If you never go any place you aren't familiar with........Probably less valuable, but still useful at times.
3. If you're just exploring, or following a friend through an area you aren't familiar with & find that you would like to ride that area again, if you have your Zumo on you can save the route, upload it to your computer, modify it, or just save it for future use. You also have the confidence that if you just go exploring you can't get lost.
4. Stealers/Dealers can be downloaded at POIFactory.com More info on uses of the Zumo can be found at Zumoforums.com.
It was cheap, works well for normal conditions.
If it looks like its going to rain I'll either put a ziplock baggy over it.
You can get some third party software called TYRE ( Trace Your Route Everywhere ). You can use Google Maps to plan your routes then transfer them over to the TomTom.
I use a Ram Mount with a handle bar clamp.
You just saved me (or at least my wife) a bundle...
