What causes this?
Old Nov 24, 2008 | 12:30 AM
Big Pa's Avatar
Big Pa
Default What causes this?
I have an '08 Road King w/ rush slipons. (Not sure what size.) In the last two or three hundred miles, I've started getting alot of decelleration popping. What causes this & will it hurt the bike? Also, how do I correct this?
Thanks, Joe
Old Nov 24, 2008 | 12:42 AM
08HD's Avatar
08HD
This is what I used around the seal of the slip-ons to seal properly. http://www.boatfix.com/shop2/scripts...dproduct=53377
You can get it at Autozone or any major auto store.
Old Nov 24, 2008 | 01:23 AM
Skidrow's Avatar
Skidrow
I had the same problem when I first put the BUB 7's on my '08 RKC. I solved the problem by calling the place I bought the power commander from and doing what they said, enriching the fuel mixture at 0% throttle position at all rpm's above 1500. Solved the problem perfectly. Hasn't affected the gas mileage at all (still get the same mpg) because the difference at 0% throttle is hardly noticeable. It's just enough to keep it from detonating in the pipe. The did say though to check the clamps first to make sure they were tight and they were. No more popping at all.
Old Nov 24, 2008 | 02:32 AM
OhioSkully's Avatar
OhioSkully
could be simple like above i put on big radius and had one of my exahust bolts come loose on me after first 1,000 miles or so got popping torqued back down and been good since.
Old Nov 24, 2008 | 06:27 AM
mjmangus's Avatar
mjmangus
Check your plugs. My 05 did the same thing. Turns out the plugs were fouled. You didn't mention how long the pipes were on before the problem started.
Old Nov 24, 2008 | 06:30 AM
RODEO's Avatar
RODEO
Check all your exhaust joints and clamps too as it could easily just be an exhaust leak. That is known to cause decel popping too.
Old Nov 24, 2008 | 06:56 AM
Big Pa's Avatar
Big Pa
Thanks Guys, I've got almost 2000 miles 0n the bike. The Rush slipons were put on when I bought the bike. Like I said, it only started the decel popping about 2 or 3 hundred miles ago.
Old Nov 24, 2008 | 07:02 AM
Dennydp's Avatar
Dennydp
Exhaust leak would be my guess.Check fasteners
fish-r-ride
Jun 29, 2015 05:58 AM
harley_nova
Jun 20, 2009 03:06 PM
scaires as hell
Oct 20, 2008 06:10 PM
Skidrow
Sep 25, 2008 12:47 PM
vailtl
13
Jul 30, 2007 01:01 AM
