Tortz Bits
Old Apr 23, 2010 | 11:33 PM
  #61
twistedcherokee's Avatar
twistedcherokee
Originally Posted by Watch Guy
How do you remove a torx head that shears off in the bolt? I have broken a craftsman torx head (tx40) off in the engine guard mounting bolt. How do I get it out?
A strong magnet works well. If it seems to be jammed & the magnet won't pull it out, then use a punch & just tap it to loosen it & the magnet should pull it out.
Sorry I did not remember to bring home the torx & torx plus bits to take a picture, got out late & was having a bad day. I will go in tomorrow & get pics of them.
Toby
Old Apr 24, 2010 | 12:32 AM
  #62
dirtracin23's Avatar
dirtracin23
Originally Posted by prostar
SK 1/2 rachet bites the big one. I have been waiting for 4 months for a rebuild kit. Mac guy says he thinks they are having hard times
At least you have a Mac man to talk to and buy from. I have all kinds of Mac tools and now no distributors within a 100 miles of me. Any problems and I have to send everything to Mac in Ohio. Pain in the ol' butt! Nothing like them taking a bunch of my money and then yanking the proverbial rug out from under me. Should have bought all Snap-On or Matco.
Old Apr 24, 2010 | 02:51 AM
  #63
kiwideuce's Avatar
kiwideuce
i hate torx bits!
Old Apr 24, 2010 | 09:25 AM
  #64
twistedcherokee
I have worked at places where one or the other didn't come to the shop, right now it's Matco & Cornwell. Although Cornwell was coming to the shop & I still owed him money. But I have had shops that Snap On didn't show up at & same with Mac, it gets irritating to say the least.
Toby
Old Apr 25, 2010 | 12:15 AM
  #65
twistedcherokee
Didn't make it to the shop, worked on tiling the kitchen counters instead. But have to go into the shop tomorrow & sand blast some of the garbage disposal pieces so will take them then. Did find this in a another post & it shows it very well.
Originally Posted by FXD2003Rider
Here's some more background info on TORX and TORX Plus screws
(source: www.screwdriversets.org/TORX-Screwdriver.html):
"Since the torx screw was designed for automated assembly it now showing up in many places including automobiles. It is even becoming popular in the construction industries.
The TORXŽ (rhymes with "forks") fastening system was developed by Acument Global Technologies' Camcar LLC group (formerly Camcar Textron) and is the trademark for a type of screw head characterized by a 6-point star-shaped pattern. People are often not aware of the trademark 'TORX' (which is always capitalized) and often refer to such a driver as a star screwdriver.
The generic name is hexalobular (hex-lob) internal driving feature and is known as ISO 10664 by the International Organization for Standardization.
One of the primary advantages of a torx fastener is the elimination of cam out. Cam out is when the screwdriver slips out of the screw head once a certain torque is exceeded.
In the earlier days of manufacturing, the Phillips screwdriver replaced the slotted driver. It was self centering which allowed for automated assembly. The Phillips head screw and screwdriver system was designed to cam out to prevent over-tightening. This was before torque-sensing automatic screwdrivers existed. These properties were used to speed up production although camming out damages the screw and also the screwdriver.
As torque-limiting automatic screwdrivers became available, the torx system was invented. By design, torx head screws do not cam out. When the desired torque is reached the driver stops applying torque. This pretty much prevents damage to the driver tip, screw head and workpiece. It also allows for the torque to be consistently applied.
The torx system is known as 'Torx T' and has the following features:
  • Straight sidewalls prevent cam out
  • Allows high torque transmission
  • Circular geometry increases drive bit engagement
  • Drivers last ten times longer than Phillips
  • 15° drive angle prevents full engagement of the drive bit and fastener
  • 15° drive anglepermits a small amount of radial stress which reduces driver bit life
TORX PLUS
Camcar LLC also developed an improved profile which they designated TORXPLUSŽ. Instead of 'V-shaped' points the torx plus has 'U-shaped' points. It has a 0° drive angle versus the 15° drive angle of the standard torx system. This allows for the torx plus screwdriver to mate better with the torx plus screw sidewalls providing greater torque and less wear.
The torx plus system is known as 'Torx TS' and has the following features:
  • Spreads driving forces over larger area which ensures optimal torque transmission with reduced clamp load
  • Straight, vertical sidewalls eliminate cam out
  • Completely encloses driver bit which reduces tool slippage and application damage and extends tool life
  • Little or no end load is required to keep the screwdriver engaged in the screw recess which reduces fatigue and muscular stress during manual assembly
  • Maximizes engagement between driver and screw (true 0° drive angle)
While standard torx drivers can be used to drive torx plus screws, it is not recommended since there will be a loose fit that prevents full torque. Torx plus drivers will not fit standard torx screws.
There is also a tamper resistant version of torx plus screw that has five lobes instead of six with a post in the center and is known as a torx TX".
TORX vs TORX Plus
(source:www.friesen.com/electric/screw_information.html)
"TorxŽ
Star-shaped drive with six rounded points allows maximum transfer of torque. Provides a high level of security without sacrificing accessibility.
Torx PlusŽ
Elliptical groove design maximizes engagement depth between driver and fastener. Ensures optimum torque transmission, and virtually eliminates camout.
(source: www.wrenthamtool.com/products/torx.asp)
The larger cross section at the lobes reduces cam-out and gives higher torque transfer capability."
Old Apr 25, 2010 | 02:07 AM
  #66
masterblaster's Avatar
masterblaster
Look at teh bottom of the PDF of the kit contents, it spells out teh torx needed for most of your bike.
http://www.cruztools.com/products/kitshd.html
I would also think hardening the bits yourself like they taught you in metal shop in junir high would help if you bought a cheap set.
http://www.cruztools.com/downloads/contentsmc.pdf
Old Apr 25, 2010 | 03:16 AM
  #67
Watch Guy's Avatar
Watch Guy
Default Well, the problem kinda took care of itself
The torx head broke off in the engine guard bolt and before I could get at it with a drill, the engine vibration shook it out. Funny how things work out. This sure has been an informative thread.
Old Apr 25, 2010 | 10:37 AM
  #68
twistedcherokee
It's not like an easy out, they fit in there loose to begin with & they don't get tighter as you turn them. I have never had a problem getting them out with a magnet, but if the magnet wont pull it out a slight tap with a hammer should shock them loose so a magnet will.
Toby
Old Apr 25, 2010 | 12:22 PM
  #69
Baffler1's Avatar
Baffler1
I luv these informative threads - marked
Old Apr 26, 2010 | 01:11 AM
  #70
Harleyboyddk's Avatar
Harleyboyddk
Be careful with torx fasteners, use torque wrench, replace damaged units.....
