Engine whine ??
Old Jan 28, 2009 | 11:04 PM
2two2's Avatar
2two2
Stage III
Default Engine whine ??
I have a 20003 electra glide classicwith a whine noise that differs with engine speed. Higher speed = greater noise. I used a stethescope to try to track down the noise. It seems to be on the right side near the area where the oil lines exit. Cam chain? oil pump? Any Ideas?
Thanks 2
Old Jan 29, 2009 | 12:46 AM
electraride2's Avatar
electraride2
cam tensioners??? how many miles on bike?
Old Jan 29, 2009 | 08:54 AM
katobird's Avatar
katobird
Can't hear the noise from here, but I had a sportster with a "whine" ended up being a bearing in the trans getting ready to let go.
galling, balling, roughness, scored, etc on bearing face/race will give whine sounds....
Old Jan 29, 2009 | 09:59 PM
2two2's Avatar
2two2
Stage III
Hi, Thanks my Glide has 36000 on it. It been sitting for a couple weeks and it killing me. I do have a deluxe too, but it's just not the same.
T
Old Jan 29, 2009 | 10:10 PM
Tripper's Avatar
Tripper
camembert and some crackers should go gud with that whine.
brock275's Avatar
brock275
Did this occur in between maintenance or just after maintenance. I've had issues with whines caused by bad adjustments during maintenance (not on the right side though).
Brock
Old Jan 29, 2009 | 11:10 PM
2two2's Avatar
2two2
Stage III
No, It started showing up about 1000 mi. ago and has been getting worse. It almost sounded like a backlash of some sort when I shut it off last itme I started it. I guess I just need to knuckel down and tear it down to find it what the noise is. I think I'll start with the cam stuff.T
Old Jan 30, 2009 | 08:33 AM
katobird's Avatar
katobird
Try using a stethoscope or go to basics, if you have a long screw driver place it near where the noise is at and put your ear against the screwdriver. Cheap man's steth......
Old Jan 30, 2009 | 08:59 AM
miacycles's Avatar
miacycles
Sounds like either a cam bearing (probably the rear one as they are usually the first to go), cam chain tensioner, or oil pump. Take the cover off and have a look, then let us know what you find.
Old Jan 30, 2009 | 09:51 AM
jaymcgil19's Avatar
jaymcgil19
try changing your fluids and strain them through a white tee shirt and also see if you got any metal on the drain plug. when you get the oil filter off try cutting an end off it to get to the filter paper and see if this gives you any clues.
orange plastic=cam change tensioners
metal chunks= big problems
a little metal powder on drain plugs maybe normal
