Clutch Cable Question
Old Feb 8, 2009 | 04:22 PM
hawkeye85's Avatar
hawkeye85
Default Clutch Cable Question
Putting new bars on my bike and went to install the clutch cable. removed old cable from the bars first then removed the trans cover. had enough slack the was able to remove cover with out removing snap ring and bearings. got my new cable installed with out removing snap ring and etc. also. Went to put cover back on. Is the tranny cover supposed to sit straight flush? or is this just some pressure when you run yout bolts in. i had just little gap on the rear then it pulled in with the bolts. Now that i have it all together my clutch cable is tight. wouldnt you think a new cable would be loose to start with or do they start tight most the time? any input would help! thanks
Old Feb 8, 2009 | 04:57 PM
lawnmower man's Avatar
lawnmower man
I' m definately not a mechanic but I know the few times I have changed cables I was told to take the tension out of the cable @ the adjuster by your engine gaurd before you remove the cable from the clutch pak. Try and adjust the cable with the inline adjuster, you should have about an 1/8 or 1/16 play at your clutch lever. If that doesn't work you with have to pull your inspection plate off primary and adjust clutch there. A service manual is great for this job if you have one.
Old Feb 8, 2009 | 05:33 PM
hawkeye85's Avatar
hawkeye85
thanks. i was able to get it right, i had a really sharp turn on my cable causing it to pull hard so re routed it and problem solved.
Streetglide2371
Jul 5, 2017 02:38 PM
WiscoKid
General Topics/Tech Tips
Jul 28, 2014 09:13 PM
Reaper_ggy
Jul 14, 2011 03:38 PM
Muskrat68
Apr 24, 2011 09:23 PM
tna1000
Jul 25, 2007 09:26 PM
