engine idle temperature management system
Old Feb 13, 2009 | 05:11 AM
Jrsess's Avatar
Jrsess
When your sitting at idle you hardly even notice it's activated. Shuts off instantly when you give it any throttle.
Old Feb 13, 2009 | 05:24 AM
JayStronghawk's Avatar
JayStronghawk
Interesting but mine came without it and no desire to add it .. but appreciate the input... My PCIII keeps it cool enough
Old Feb 13, 2009 | 08:51 AM
Kugie's HOG's Avatar
Kugie's HOG
Originally Posted by Xcrossbow
Here's a recent thread that on page 2 starts a "discussion" of the system.
https://www.hdforums.com/forum/touri...he-heat-2.html
If you go to above link & go to response #28 I have detailed info on how it works for the 09. I know for 09 I was informed you cannot turn this on with bike running. That is why I always leave mine on. Several friends that have 08 models aslo said they cannot turn it on with bike running.
Old Feb 13, 2009 | 08:54 AM
Kugie's HOG
Originally Posted by sonar_chris
Sorry, but you role the throttle forward not back. It wont increase your idle speed and you can turn the idle heat management on and off while the bike is running or not. Also it only works while you are stopped, once you start moving it shuts off.
I'll have to try turning it on while bike is running because I was told it will not activate. Thanks for the info.
Old Feb 13, 2009 | 10:15 AM
sonar_chris's Avatar
sonar_chris
It turns on and off on my 09 RG while the bike is running. The cruise control light on my tachometer tuns amber (off) and green (on) while the bike is running if I role the throttle forward for more than 5 seconds.
Old Feb 13, 2009 | 08:03 PM
ezriderpgh's Avatar
ezriderpgh
You are correct, you roll it forward from idle position. It will stay active in parade conditions, try it. Bottom line is it sucks anyway.
Old Feb 16, 2009 | 07:03 PM
Richpend's Avatar
Richpend
I tried it yesterday, the green light came on when I was stopped and just idling, do you just go from there or do you have to deactivate it first? In other words I can just leave it activated once I turn it on then once you start to moving it will shut it self back off until you are ready to use it again, then repeat the process of rolling the throttle forwards until the green light comes back on, or will it already be on once I roll the throttle forward?
Old Feb 16, 2009 | 07:30 PM
sonar_chris
When you role the throttle forward and the cruise control light flashes green the temp management system is activated. It doesn't work all the time, it is temperature sensitive, it will only work above a certain temp (what temp I don't know), if it didn't work this way your bike would take a long, long time to warm up to proper operating temp. You will definitely know when it kicks on at a stand still, your idle will be come rough and you will smell a unique different kind of smell. As soon as you give it any gas, the rear cylinder fires again. It is a seamless transition. The EITMS only works while stopped and at idle it doesn't work while you are moving. You can activate it while the bike is running or off but you have to be sitting still. If the cruise control light flashes amber when you role the throttle forward you have deactivated the system. Hope that explains it all.
Old Feb 16, 2009 | 07:36 PM
Richpend's Avatar
Richpend
Yes Thanks!!
Old Feb 16, 2009 | 07:38 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
a good tune will elimenate the need for it its a band aid fix for the lean conditions that cause it to run hot in the first place,as far as im concerned it doesnt activate untill its allready too hot.
