engine idle temperature management system
Old Feb 16, 2009 | 07:43 PM
sonar_chris's Avatar
sonar_chris
Originally Posted by bigdumbnoitall00
a good tune will elimenate the need for it its a band aid fix for the lean conditions that cause it to run hot in the first place,as far as im concerned it doesnt activate untill its allready too hot.
Even a well tuned air cooled motor will overheat in traffic. While it may be HD's band aid for factory lean condition, it will still help a well tuned bike in the same conditions.
Old Feb 16, 2009 | 08:40 PM
Dionicio's Avatar
Dionicio
You are correct. I like it's operation, and it gives me peace of mind that My engine is protected.
Old Mar 20, 2009 | 04:48 PM
Falconer14's Avatar
Falconer14
Stage II
Default Engine Idle Temperature Management System
I understand the concept, function, and operation (turning it on and off) of the Engine Idle Temperature Management System. My issue is that I suspect the feature is turning on & off by itself. The idle suddenly gets rough and the exhaust from the rear cylinder gets that bitter smell. A cat that I see at the gym says that he has heard that in fact the feature has been doing just that and that there is a download Harley can do to correct it. I have a 2009 Road King Classic. Anybody out there have any ideas about this? Thx.
Old Mar 20, 2009 | 05:50 PM
ranman469's Avatar
ranman469
Originally Posted by JayStronghawk
Interesting but mine came without it and no desire to add it .. but appreciate the input... My PCIII keeps it cool enough
ok i`m getting confused??
i read in another post that the pc does not change afr below 1400? if so how does it cool?
not being a *** i just dont know?
Old Mar 20, 2009 | 07:42 PM
HEMSPLT's Avatar
HEMSPLT
In a nutshell, Harley, and other manufacturers, make their engines run lean to help meet EPA pollution limits but a lean engine will run hot. Not a big deal in a watercooled engine but it is more noticible in a stationary air cooled motor. If you add fuel to the fuel/air mixture the engine will run cooler. Aftermarket engine management systems such as PC III, PC V, ThunderMax, TTS, etc, add more fuel at idle, which richens the fuel/air mixture (ratio). This helps the engine run cooler but you are likely causing more pollution. Most, if not all, of the aftermarket fuel management systems are illegal in the People's Democratic Republic of Kalifornia for this reason.
DRAGO1
Exhaust System Topics
Mar 11, 2013 07:18 AM
SwitchHD
Feb 26, 2012 08:14 PM
warthawg
Aug 18, 2008 09:57 PM
mad4249
Aug 13, 2008 09:12 AM
bob_kikkert
Jun 3, 2008 05:17 PM
