Need some 103 advice
I had the 103 upgrade, with the SE255 cams, cost was about $1400 with a dyno tune included. I already had the Stage I breather kit and a PCIII, as well as true duals installed before the upgrade. You need to give very strong consideration to having compression releases installed when the heads are off. It'll cost a little more, but you will have to have them before you are totally satisfied with the entire upgrade. I know, I know, it says 9.5 compression, etc, and you don't need them, but you are going to have starting problems as a result of the upgrade. People will tell you they did this, they did that, they had a good dyno tune, they had this cam, they did all kinds of stuff and they don't have to use compression releases. I say BULL SHEET. It's gonna cause problems, you just as well cure it while the engine is apart, have the compression releases installed while they can do it cheaper. If you don't believe me, try it without them. You'll find out the hard way (just like I did). PACO
A dealer is having a special price on SE 103 big bore kits. They quoted $795 plus tax on the big bore parts and labor. Quoted $1400 for big bore and 203 cam parts and labor. On top of the cam cost, there would be a need for a SERT, Power Commander, etc, or the HD stage II download. What does everyone think about the deal. The big bore price seems right, but the price with cams seems a bit steep.
H-D only recommends the 203 cams for "up to 96 ci" motors. Your dealer should know this.
Also, because of the SE 203 cams, I don't see how he will have a correct download for you since HD downloads are build-specific and that BB kit with 203 cams is not intended for your 96. He'll have a download for that kit on an 88, and a download for the SE 255 cam kit on a 96.
If you go to this link from HD's website, you can see the various SE packages, including those for the 103:
http://www.harley-davidson.com/wcm/C...p?locale=en_US
I did the 103 stage II with 255 cams and a SERT and a Dyno Tune for $1900 then I added a D&D fatcat with ghost pipe for another $900. I got 89 HP and 101 TQ. I am very happy with the power for the money spent. Dealer does 25% off parts and 25% off labor in the winter, makes for some smoking deals.
Here's my 2 cents. Put the 103 kit on my 2007 Road King with Andrews 54H cams. Couldn't be happier with the power, but the bike wouldn't start when hot, took about 20 minutes to cool down enough to start easily and knowing how delicate the stock Harley starters are I had to take it back apart and add compression releases, problem solved. I do all my own work, so it was just a matter of time for me, but if your having to pay someone, then I'd have the releases installed and save yourself the trouble and expense later. Also research the cam situation before using Harley cams, you will be alot more satisfied with Andrews or Woods cams. Just my opinion.
