Chrome Switch Cap Install.
Old Apr 4, 2012 | 03:40 PM
  #41
1st 96 ultra's Avatar
1st 96 ultra
did the chrome buttons on my 96 Ultra , broke one switch and had to glue one button on so it would stay , like the black look on my 07 JUST FINE
Old Jun 18, 2012 | 01:47 AM
  #42
Dangerous Rogue's Avatar
Dangerous Rogue
I just installed this while doing a handlebar swap. Honestly, I think I spent more time on these as on the whole rest of this project....PITA! Reassembling the housings with the radio controls is what really got me and I was not happy forcing the radio/cruise controls on the tiny stems. I ended up drilling them out a bit and using epoxy to hold em on. I sure hope the next guy likes chrome switches. The end result however was worth it.
Old Aug 5, 2012 | 09:22 PM
  #43
Jay Walker's Avatar
Jay Walker
1st Gear
I just did mine today...
After you open the housings there is one small torx screw holding each button sets (one on top and one on bottom).
I did the left ones first. When I realized how much tighter they fit than the stock ones, I decided to let the right sides sit in the sun while I removed the stocks. I don't know if it helped, but, I wanted to believe it did.
A small screwdriver is be VERY helpful when doing this. Also, make sure you know what position the "gear" peg is in. The caps have one side that is a plain circle that attaches to one side of the switch peg. That is- it's a smooth fulcrum. the other peg is a sort of gear/toothed, that is the actual control of the switch. This matches up with the switch cap. If you get the cap on and it's in the "up" position and the actual gear of the switch is in the "down" position, it won't move.
The blinkers, horn, and start buttons have a spring in them that returns the respective switch to its original position. Just use the screwdriver to gently ease them out and put them aside. They won't unravel, they're not that kind of spring. They're like a hinge spring. They do have tiny holes that the ends need to be put back in eventually.
Oh, and I tested each switch as I went. I think that saved a bit of heartache down the road. This is because of that thing I mentioned earlier. Yeah, I had the left blinker in the "blink" position and the switch in the "not blink" position. Taking it off and on again mad me cry a little bit. The blinker springs didn't need to come off, but, they're a little more tough.
I think that's all the tips I have. Hope it helps. I took photos as I went and will upload some soon.
Old Aug 5, 2012 | 11:38 PM
  #44
Jay Walker's Avatar
Jay Walker
1st Gear
If you've never removed the grips, make sure you loosen the cables all the way...
Here, you can see the torx screw....
[/IMG]
Every "geared" side of the switches/caps seem to have a line that lineup when installed properly. The chrome caps do not have that line. Just make sure you know where they are or photograph them. Most aren't easy to move by hand...
Done
And done
Old Aug 6, 2012 | 01:10 AM
  #45
ReidRik_Von's Avatar
ReidRik_Von
Default Try a hair dryer
Originally Posted by pappy
I put them in real hot water for 10 or 15 min to soften them up and they go on a lot better.
Like many other, my cracked when I first tried to install in the cold garage last winter. Returned them to the dealer and they swapped for a new set. On take 2 I used my wife's hair dryer to get them hot and they went on much easier:
Old Aug 6, 2012 | 10:24 AM
  #46
RaceFace's Avatar
RaceFace
Wow, after reading this thread, I'm glad I decided to leave the black ones on for contrast. Sounds like a PITA!
Old Jul 14, 2013 | 09:34 PM
  #47
Firechaser1141's Avatar
Firechaser1141
how dose the radio volume buttons come off?
Old Jul 15, 2013 | 09:57 AM
  #48
myred55's Avatar
myred55
They pull straight off. Soak the switch caps in hot water, make it a lot easier to install.
Old Jul 15, 2013 | 03:29 PM
  #49
Firechaser1141
Thanks i thought so but didnt want to just go tuggin on them and brake them.
Old Jul 15, 2013 | 05:57 PM
  #50
Punjabi Rider's Avatar
Punjabi Rider
I put on my bike but quality is not that great compare to stock black ones .
