Pc v -
Old Mar 8, 2009 | 02:54 PM
BillyG0856's Avatar
BillyG0856
Thumbs up Pc v -
Received my PC V last Tuesday...just as Keith said it would be delivered. I was working GRAVEYARDS Tues, Wed, Thurs nights....so it was Friday aft before I got it installed. Bike fired right up...took it for a short ride.....WOW! As everyone else has said.....it's GREAT!
No ride Sat due to the fact some a@@hole broke into my deer camper.....had to go n repair that....and today, Sunday, Im WORKING OT....AGAIN (sounds like funding for an AT in the near future). Did ride the bike to work this am....was having a blast just cruising into work @ 4:30am. It's not very often I can cruise by the police station @ 80 mph.....hehehe. Planning on taking a ride when I get off this eveningl Im not even gonna worry about mileage at this point....just gonna listen to her run!
Thanks to Jamie and Keith....and everyone else here on the forum for the threads / discussion!!!
Billy G
Old Mar 8, 2009 | 08:44 PM
BillyG0856's Avatar
BillyG0856
Took about a 50 mi ride this afternoon after work....bike ran GREAT! Acceleration is so much better....heat on the right side is minimal. If the laptop is available @ work tomorrow....Im going to check the ZERO on the throttle.
But....when I got home...was putting the bike in the shop....my 'check engine' light came on....WHY?....I have no idea. I remember seeing a thread where someone had the same problem....Ive searched...to no avail. Can anyone help me?
Im going to check the O2 plugs shortly...just to make sure they're ok. This PC V is a great improvement....just wanna find out what may be causing the light to come on.
Appreciate any help... Thanks
Billy G
Old Mar 8, 2009 | 09:08 PM
cardboard's Avatar
cardboard
Had mine on for 2 wks, guess i'm the only one with the A/T modules.
Old Mar 8, 2009 | 09:17 PM
BillyG0856's Avatar
BillyG0856
Well.....they way the bike was running this afternoon....I was thinking about the AT to go with it. Matter of fact....I'd planned for today's OT to go for just that. Now, until I figure out what's wrong.....dunno.
I just had the bike serviced last week.....5000 mi service....and my clutch isnt right....maybe it's just that. Going to try and get it in this week....might be Friday before I can though.
Billy G
skratch's Avatar
skratch
does the pcv use a terminating plug on the o2 harness like the pcIII did?
Old Mar 9, 2009 | 04:45 AM
luc.who's Avatar
luc.who
Yes there are terminators for each sensor.
Old Mar 9, 2009 | 06:29 AM
BillyG0856's Avatar
BillyG0856
LOL....my owner's manual was in my locker @ work.
Just checking thru the manual, the 'check engine' light is concerned with engine management. Maybe by 'ZEROing' the throttle, it'll satisfy the sensor.....
I'll get that done as soon as daylight comes.
Old Mar 9, 2009 | 07:06 AM
09StreetGlider's Avatar
09StreetGlider
Billy, on your 07 you can easily adjust 0% and 100% throttle since you don't have TBW.
Let us know if you continue to have trouble. Have you attempted to find out what code is being set? You can read the codes with the odometer. Do a search for ECM Codes and find the correct procedure for your year and let us know which code it's throwing.
If the check engine light comes on after startup and then goes out again after a few seconds then the code is historical and will go away after 50 ignition cycles unless you reset it yourself through the odometer. No need to worry over a historical code.
If the light comes on after startup and stays on...this is a current code and requires immediate attention and diagnosis before continuing to ride.
Let us know what you find out.
Old Mar 9, 2009 | 10:55 AM
BillyG0856's Avatar
BillyG0856
Thanks for the info. Did the search...found procedures and code descriptions. By the codes that came up, all under the "P":
131- Front O2 sensor LOW,
134 - Front O2 sensor open/not responding,
152 - Rear O2 sensor HIGH.
Im going to recheck the O2 modules...coat with dialectric grease, and call Jamie / Keith and see if I need to remap. Will keep advised.
Here is a link to the codes info
http://www.hdtalking.com/diagnostics...ctivation.html
Billy G
Old Mar 9, 2009 | 11:12 AM
JustDennis's Avatar
JustDennis
Almost sounds like the O2 terminators are not working correctly. DId you have any problems installing them?
