Headlamp alignment
Old Apr 28, 2006 | 03:58 PM
KenM's Avatar
KenM
Default Headlamp alignment
I replaced the bulb to one of the blue/white brighter models and now I'm getting flashed at.
It seems that my dim beam is too high and my high is up in the trees. I flick the high beams on and the flashing stops.
Is there a method to do this other than trial and error? If I park in my garage and sit on it, can I use the wall to gauge the heith etc. ?
Are there any measurements that are a standard that maybe get used in the plant.
Thanks
Old Apr 28, 2006 | 05:30 PM
ricoman's Avatar
ricoman
Default RE: Headlamp alignment
If you have your Owner's manual, it is covered there. You may be able to get the info from a manual at the dealer.
Try this - put the bike 25' from a wall; measure the height from the floor to the center of the headlamp with the bike upright (not on stand); make a mark on the wall at the same height; turn on light & aim toward the wall. The center of the beam should be on the mark on the wall. Also check the lateral alignment so that there is equal light to the left and right of the center of the bike.
Don't forget to have weight on the bike equal to the normal rider's weight. Be sure your garage floor is level (most are not).
Old Apr 28, 2006 | 05:48 PM
KenM's Avatar
KenM
Thanks Ricoman!
Makes sense to me.
Old Apr 28, 2006 | 07:44 PM
RBJones's Avatar
RBJones
Ricoman's the man. Make sure it's on high beam when you check it, not low beam.
Old Apr 29, 2006 | 12:40 AM
mikeisglidn's Avatar
mikeisglidn
i like gettin flashed, it means the azzholes can see me!!!
Old Apr 29, 2006 | 12:51 AM
HD Renegade's Avatar
HD Renegade
Mike that is a Bad Atitude, and I like it!!!!!!
Bob
ORIGINAL: mikeisglidn
Old Apr 29, 2006 | 12:54 AM
mikeisglidn
yea im a nasty little falker!!
har1690
2014-2024 Touring Models
Jul 5, 2017 01:40 PM
steelerdude1
Sep 17, 2014 02:29 PM
BuzzCap7
Sep 4, 2012 09:40 AM
Pop Yearwood
Jun 18, 2012 05:21 PM
RonRock
Sep 7, 2009 09:17 PM
