Plug and play. You installing it (inline) between your existing ECM and the harness that plugs into it. Although you will have to download a map onto the PC-V, unless you purchase it from Jamie at Fuel Moto (highly recommend)....Putt
I did get the PCV from Jamie along with the Jackpot package.
So all I have to do place the PCV in between the wiring harness and the ECM? That's it? Then I have to install the 02 eliminators, right? Then tuck everyting away. Is that really all there is to it?
Thanks
That's pretty much it. The only things that were even a question to me were "How do I disengage the connector?" I had to wiggle it a little and the next thing was routing the conncetor beside the battery. You will see it on the instructions you get from Jamie. Mine were very good.
All Plug and play and learning wire management! You'll do fine...hey...I've said this before...I'm Polish and was born blonde...if I can do it...anyone can!
Very E-Zit took me 12 minutes to install, just make sure that you tie up the lose sensor wires nice and snug. Don let them come in contact with a hot surface.
very easy install PCV took only about 15 min and AC in 10 now the pipes where a diffrent story LOL....PS Fuel Moto is the way to go I had my 07 done at a dealer w/SERT and dyoned this set up runs much better and no popping
