Protecting Electronics While Welding Question
Old Mar 31, 2009 | 11:46 PM
jeff194's Avatar
jeff194
Default Protecting Electronics While Welding Question
I need to know how to properly protect my bikes electronics while using a mig welder. I may tack a bracket on for a project I am considering and don't want to damage anything (ECM etc). Whats the right way to do it?
Old Apr 1, 2009 | 12:16 AM
JohnCA58's Avatar
JohnCA58
The safest method is disconnect the battery + and - post, and remove the ecm connector also, and run the stinger and ground as close together as possible.
Old Apr 1, 2009 | 12:21 AM
OhioSkully's Avatar
OhioSkully
+1 on what John said. Best advice and about all you can do. Thats what we do in the factory on a machine with plc's and electronics kill the power and keep your ground clamp as close to where your welding as possible shortens the path and with power off on machine or battery should be ok.
Old Apr 1, 2009 | 06:55 AM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
You shouldn't weld electronics, you should solder them instead.
Old Apr 1, 2009 | 07:41 AM
MILO851's Avatar
MILO851
Whenever I do this i disconect battery and try and put the ground on the piece you are welding-tacking on
Old Apr 1, 2009 | 12:58 PM
jeff194's Avatar
jeff194
Ok, Thanks for all the replies.
zach spradlin
2014-2024 Touring Models
24
Feb 12, 2017 10:15 AM
fame2
Dec 4, 2014 08:53 AM
BuzzL
Nov 21, 2013 01:19 PM
Sharkman73
Mar 14, 2012 05:49 PM
Sammi
Nov 8, 2011 10:31 PM
