can someone please give me these torque specs (road king)
I am putting on some wheels i just powdercoated... i need the torque specs for the rear pully bolts, rear rotor bolts, and front rotor bolts... can someone with a service manual help me out?
thanks... ooh ya it is a 100th aniv edition if htat matters
You have a 2003 and I have a 2007, but her is what the good book says...
Rear Pully Bolts...55-65 ft-lbs
Rear Rotor Bolts...30-45 ft-lbs
Front Rotor Bolts...16-24 ft-lbs
I would double check, but this should get you close.....
Grizz02 (05-29-2017)
Additional numbers you may be interested are
frt axle 50-55 fp
frt axle holder 132-180 inch lbs
rear axle 95-105 ft lbs
Quote"Thats correct for 07. But its all the same Im sure. It also says rotor and pully bolts are a 1 time use, and always use locktite. Red on pully, blue on roter"
Many bolts on Harleys are to be only torqued once. Some are torqued then loosened and then re-torqued. Always refer to your service manual for the correct information.
Di Simone...how's about you lighten up on Wild bill? There's a bunch of folks on this forum...myself included...who believe that if you're gonna wrench on a bike, get the manual first. Personally, I resent like hell when I've gone out and make the investment in a manual, some guy who's too lazy or too cheap to spend fifty or sixty bucks on the manual, and coming on this forum and expecting that someone is gonna give up the answer! Yeah, he's probably gonna get it cuz many folks are oh so helpful.
Now then...there are situations where a guy has ordered one and it hasn't come in, or he's away from his manual, but generally an OP will 'splain that up front.
No need to get on somebody's face or call him names.
