Speedo Malfunction
Old May 8, 2006 | 11:20 AM
daboys53119's Avatar
daboys53119
Default Speedo Malfunction
I was out yesterday enjoying the great weather here, got in about 200 miles! Problem I had was for about 10 miles the speedo on my 2000 Ultra quit functioning. The needle would not go above 40mph or under 20 mph. After I stopped for fuel the speedo started working fine. Do I have anything to worry about?
Old May 8, 2006 | 12:15 PM
PhilM's Avatar
PhilM
Default RE: Speedo Malfunction
More than likely the sensor has metal shavings on it.
It's an easy fix. The sensor is on the top of your tranny, just below where the rear pipe comes out of the head. It's a black device with a fairly thick black lead coming off of it. It is held in place by a single allen screw. Remove the screw, pull the sensor out by wiggling it is you pull upward on it. Remove the built up metal shavings and re-install the sensor and allen screw....
I bet that will fix it!
Old May 8, 2006 | 12:33 PM
daboys53119
I will try that tonight, thanks!!!
yooper49
Electrical/Lighting/Alarm
May 28, 2017 05:43 PM
Sportster334
Sep 11, 2014 07:46 PM
Fathead2003
Sep 9, 2011 05:37 AM
bigskyhd
Aug 12, 2009 05:40 PM
Zutroy
May 3, 2007 03:11 PM
