SERT Help
Old May 10, 2009 | 12:59 PM
DiegoKing's Avatar
DiegoKing
Default SERT Help
Hey All,
So I find out by talking with the previous owner of my King that here is a SERT installed. The problem is since I've owned the bike I have have made major changes like cams, exhaust and air cleaner. Unfortunately I do not have the SERT so I cannot change the program. Any way to return the ECM to stock so I can load a custom MAP with my PCIII?
Thanks,
Old May 10, 2009 | 01:07 PM
dawg's Avatar
dawg
What did he do with the dongle?
Old May 10, 2009 | 01:33 PM
2005UltraNC's Avatar
2005UltraNC
Without the dongle, you're out of luck. The dealer can return to stock. But, like Dawg said, would try and locate the SERT dongle - it's useless to anyone else.
Old May 10, 2009 | 05:25 PM
maineultraclassic's Avatar
maineultraclassic
Yup........what they said.
Without the dongle from the SERT kit, you're screwed. Ask the previous owner where the SERT kit is and the cables to go with it.
Steve
Old May 10, 2009 | 06:41 PM
DiegoKing's Avatar
DiegoKing
Ok, so if I get the dongle, what then?
Old May 10, 2009 | 06:46 PM
dawg's Avatar
dawg
If you get the dongle then you can hook it up to a PC with cables, or have the dealer do it and put it back to stock configuration.
Old May 10, 2009 | 06:49 PM
Bigredone's Avatar
Bigredone
You don't need a PCIII and a SERT. If you get the dongle, take off the PCIII and find a good tuner with a dyno in your area.
Old May 10, 2009 | 06:56 PM
DiegoKing's Avatar
DiegoKing
What's better....a PCIII or a SERT?
Old May 10, 2009 | 07:02 PM
buttman's Avatar
buttman
Have a good custom tune done by a competent tuner, then sell the PCIII on e-bay.
Old May 10, 2009 | 07:07 PM
buttman's Avatar
buttman
The SERT, it can tune any engine you may want to build in the future. It also has the ability to read the knock sensor on the motor, making high compression builds easier to tune for no ping. The PCIII has a limited range of timing adjustment.
