blinker problem
Old May 21, 2009 | 09:15 AM
americanthunder's Avatar
americanthunder
Default blinker problem
I experienced blinkers not working today. Its not that clear cut though. The left side stopped working and I got the red key light. The right side worked at that point. Then the right side stopped working but I noticed the 3 leds for the licence plate light are faintly on but the taillight works fine. I checked all conntections, load resisters, light plugs and nothing is loose that makes them turn back on. If you unplug them and plug them back in they work for 1 or 2 blinks. What could be the problem?
Old May 21, 2009 | 09:20 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Do you have a run/brake/turn module? If so try removing that and see if the problem persists.
Old May 21, 2009 | 09:40 AM
americanthunder
No I don't have the run turn brake the only thing upgraded is radiantz leds in every light with kuryakyn load equlizers
Old May 21, 2009 | 09:41 AM
TheShrink's Avatar
TheShrink
Lose the Kuryakyn le's and get a Badlands Illuminator.
Old May 21, 2009 | 10:44 AM
baldeagle503's Avatar
baldeagle503
Sounds like the problem is in the le.
Old May 21, 2009 | 11:02 AM
StreetGlideMedic's Avatar
StreetGlideMedic
+1 to this! Kuryakyn still has alot to catch up in the market on this...while Badlands Illuminator is definitely best in My book! I have it on My bike and they work without an issue! Good Luck on your troubleshooting!
Ride Safe, Mike
Old May 21, 2009 | 11:09 AM
oldbagr's Avatar
oldbagr
Problem is the load equalizer(s). Kury makes several different LE's, make sure you have the right ones for your bike. Your best longterm solution is to replace with the Badlands Illuminator.
Old May 21, 2009 | 06:08 PM
americanthunder
I have the right ones. I don't have security they worked fine for like 6 months and then poof on the highway left light goes out. How does that explain the license plate lights going out?
Old May 21, 2009 | 09:28 PM
savingforhog's Avatar
savingforhog
did you check to see if you need blinker fluid? lol
Old May 21, 2009 | 11:11 PM
TheShrink's Avatar
TheShrink
All of the Kuryakyn load equalizers have issues and they burn out. You said yourself that if you unplug them and plug them back in, they work for a while. That's how long it takes to heat that piece of garbage up. Go here, (http://www.badlandsmotorcycleproducts.com/), and get the Illuminator.
Snowden
Sep 20, 2015 10:09 PM
hbsoldier3
2014-2024 Touring Models
Jun 21, 2015 12:06 PM
dlrshort
Jun 28, 2011 05:56 AM
smyzers
Electrical/Lighting/Alarm
Jul 2, 2010 08:04 AM
S_I_N_N_E_R
Mar 11, 2008 11:45 AM
