Problem with headlight modulator
Old May 25, 2009 | 08:43 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default Problem with headlight modulator
I just installed a Bikerbuddy headlight modulator. It seems to work as it should during daylight hours but when the sun goes down it still has an erratic flash which it should not do. It only does it when the engine is running, turn the engine off and the erratic flash stops. Got any ideals as to what it could be, something to do with the charging system maybe since it only does it when the engine is running? Also there is no problem with the low beam it works perfect engine running or not day or night.
Old May 25, 2009 | 10:10 PM
OLD 96's Avatar
OLD 96
dontdropit,I can't tell you what the problem is. Because electrical gremilns are the worst. But, if you don't mind my advice. I would tell you to take it off and throw it as far as you can. I had one and it gave me nothing but TROUBLE. It had me chasing ghosts all over the bike. Not worth it.
On top of that when cagers saw that it was a motorcycle and not an emergency vehicle it would appearantly **** them off and they would pull out right in front of me.
Old May 26, 2009 | 07:16 AM
dontdropit's Avatar
dontdropit
xxxxx
MrMojo
May 26, 2011 05:27 AM
dontdropit
Touring Parts
Jun 12, 2009 08:13 PM
scooter34
May 29, 2009 04:00 PM
blueglide88
EVO
Aug 14, 2008 02:55 AM
skullandcircle
Sep 15, 2007 03:31 AM
