Turbo???
Old Jul 13, 2009 | 07:35 AM
Long124's Avatar
Long124
Hmmmmmmmm.....seems like somethings brewing.
Old Jul 13, 2009 | 08:32 AM
doorsidedown's Avatar
doorsidedown
Try a 124" Zipper motor. That should tickle your fancy...
Old Jul 13, 2009 | 12:12 PM
Biggzed's Avatar
Biggzed
Originally Posted by FastBagger07
Zach,
The only one assuming anything is you.I have not one doubt in my mind.Dont ever under estimate the performance of a ProCharger.
You guys are taking this way to seriously. I have no idea what kind of Zuk 750 you raced or for how long you raced it, so I dont' know what to think about that. Obviously anytime a HD beats a 750 4 cylinder metric that HD is making some power. I don't doubt that for a minute.
For the record, I never said I would beat you. I only said it would be closer than you think and I stick by that.
My dyno sheet and build is in the Dyno for baggers thread. Page 113 I think. The only thing I have on the bike that is not listed on that post is an Evo 30 tooth sprocket. That's all I meant by stating "you assume too much".
So our bikes weight roughly the same, are geared the same, and make similar over all power. You have 11 more hp than me. I have 12 more ft lb tq than you. As you can see in my dyno chart, I'm making tq very early and hp rises moderately, but steadily. The forced induction dynos I have seen in the past make peak numbers higher in the rpm range. That's the only reason I think I would be able to hang with you for the majority of a 1/4 mile run. I could be completely wrong and would have no problem getting my *** handed to you. In fact, I'd probably shake your hand and get you drunk.
That's it for me. I was just tryin to bench race a little with you. Not trying to ruffle anyones feathers. Now go beat up on some more sport bikes. They all deserve it. LOL
Zach
Edit to add: I've got about $2900 total in my build, including the dyno session. If you're not double that for the ProCharger, you're very close.
Old Jul 13, 2009 | 03:31 PM
FastBagger07's Avatar
FastBagger07
Zach
All B.S. aside my ProCharger installed and tuned I have only $4800 in it.The beauty of it all is when I get tired of this bike I'll pull it off and put it on the next one.Everybody is so hung up on this forum with HeadQuarters this and HeadQuarters that.Bigger is not always better.I'm telling you these Pro-Chargers and Turbos are the way to go.With abuilt motor you have the constant high compression and big cams beating on your lower end which in time fails.Unless you build that also ,which most people neglect to do.Where a ProCharger is only hard on the lower end when it's boosting ,which only when your getting into it.Dont get me wrong the lower ends will fail eventually also.Just My 2 cents. Each to there own.
Old Jul 13, 2009 | 05:22 PM
Biggzed's Avatar
Biggzed
Good enough FastBagger. Take good care and ride hard.
Zach
JamesYeager
Harley Davidson Videos
Mar 23, 2017 02:50 AM
gartec81
Nov 9, 2011 08:30 PM
Big Twi$t
98
May 18, 2011 10:15 AM
VETERAN75
Aug 14, 2010 07:23 AM
sooie
Apr 22, 2009 11:27 AM
