headlight trim ring
Old Jul 9, 2009 | 03:07 PM
rookiedan's Avatar
rookiedan
Default headlight trim ring
to all that have installed the HD chrome trim ring around your headlight. after you installed it did you have a gap between the ring and the headlight or did it fit tight? i believe the trim ring attaches to the existing one on the lip so it can only go on so far when installing it. Comments appreciated.
thanks
Old Jul 9, 2009 | 03:09 PM
bkelly1956's Avatar
bkelly1956
tight fit...07 street glide
Old Jul 9, 2009 | 03:10 PM
casique's Avatar
casique
The trim ring is a POS! I could not get mine to fit correctly and returned it.
Old Jul 9, 2009 | 03:11 PM
ndnguyd's Avatar
ndnguyd
I had a 1/4 inch gap, kind of a chit fit...
Old Jul 9, 2009 | 04:02 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
How many more trim ring threads can we fit on here?
Old Jul 10, 2009 | 12:42 AM
JohnScrip's Avatar
JohnScrip
I've never seen one that fit remotely well.
I've seen plenty that don't even come together (even when correctly installed). I've never even seen a photo of one that actually hugs the glass...
Old Jul 10, 2009 | 12:49 AM
emwolb's Avatar
emwolb
i bought one of the visor type that goes on over the stock ring on my streetglide. after trying to get it to fit right for an hour or so, i thought, man what a cheezy piece of crap. could have found something that fits this well from a street vendor in tijuana. returned it the next day. the only way i'd install one again is to spark up the tig and weld the headlight trim ring to the original ring, and rout out the correct headlight adjustment holes, etc. in my thoughts, it's what harley should have done in the first place, is to make the trim ring, an actual trim ring that replaces the factory rounded one altogether, rather than just one that slips in over the stock ring.
Old Jul 10, 2009 | 12:53 AM
fxdxrider's Avatar
fxdxrider
Fitted a visor type ring to my 08 RKC - took several attempts to get it right - big gap otherwise. It is a piece of rubbish though.
Old Jul 10, 2009 | 07:31 AM
Cloud09King's Avatar
Cloud09King
Took the stock ring off, bought some weatherstripping at home deopt, wrapped it around the out edge of the lamp housing & installed the new trim ring. Some areas around the trim ring aren't perfectly tight & flush but the bottom where it comes to together is perfectly tight & it's the best your gonna get if you want this trim ring on your bike.
Old Jul 10, 2009 | 07:51 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Yeah but it looks so good.
