PCIII accelerator pump
Old Jul 15, 2009 | 12:31 AM
flea402's Avatar
flea402
Default PCIII accelerator pump
anybody use this on their PCIII yet. How did it work out for ya?
Old Jul 15, 2009 | 05:29 AM
HD Renegade's Avatar
HD Renegade
I too have wondered about what the beneifts would be to use this?? I can see you can make a few changes up and down for throtle sensitivity and what not.
Old Jul 15, 2009 | 06:29 AM
BadBobOk's Avatar
BadBobOk
I don't think you need to worry about this feature unless you have a highly modified engine.
Old Jul 15, 2009 | 07:06 AM
nvsteve's Avatar
nvsteve
Agree. Every tuner I've talked to including Jamie at Fuelmoto say not to use it.
Old Jul 15, 2009 | 08:29 AM
SG 1's Avatar
SG 1
I sure would like to hear more about this. Could be why my gas mileage sucks.
Old Jul 15, 2009 | 12:06 PM
nvsteve's Avatar
nvsteve
Yes, it could be. Some people had issues with early 07 models with the PC. Some enabled the accelerator pump to help resolve the issue. I believe Dynojet had firmware upgrade to fix the problem. I have an early 07 and didn't have the issue. I don't think it was wide spread. If you got your PC from Jamie, give him a call.
Old Jul 15, 2009 | 12:27 PM
HDRider2002's Avatar
HDRider2002
I've tinkered with the accelerator pump feature, and i have to say i dont' really notice much difference either way. at that point i just disabled it figuring if i don't notice the difference, then what is the use of having it?
Old Jul 15, 2009 | 05:24 PM
SG 1's Avatar
SG 1
I did get it from Jamie and I asked that the accelerator pump be enabled, so I assume that it is. I just got it at the end of last year right before the PC V was adapted to work on the 07's, so I'm sure it is an updated model. Guess I'll hook it up to the laptop and make sure and turn it off if it is and try it.
Old Jul 16, 2009 | 04:05 PM
HDRider2002
it may be enabled but depending on the settings, might not be "operating". You have to set the throttle sensitivity that activates it, as well as the added fuel delivered, and the duration of that addition.
I do have the Rev X-tend enabled on mine. I've bounced off the redline more than a few times when stock, but not since the rev x-tend has been enabled.
Old Jul 17, 2009 | 12:14 AM
EZ48's Avatar
EZ48
I've been running it or about a year now.. seems to provide a bit of snap when you twist the throttle... not a huge difference but noticeable. I have not seen any change in mpg with it enabled vs disabled.
anubisss
Nov 1, 2008 09:50 PM
05Fatty
May 26, 2007 08:57 AM
05Fatty
May 14, 2007 03:04 PM
dchoran
Oct 27, 2005 11:45 AM
Anthony8858
Oct 26, 2005 05:29 PM
