I removed the battery to run some wire for a set of fog lights. Now i cant remember how the hold clamp for the battery went.thanks any help would be great
clamp is rectangular but more like a Z from side-view. Looking straight down on battery, clamp hole will be to your far right, as the clamp will affix to frame with bolt, again far right (lower right). The clamp actually sits level with battery in-place, foam under left side of clamp (away from bolt-side). Bolt goes through clamp, pressing down on clamp keeping battery secure.
