report on lifter problem
Old Jan 31, 2010 | 10:59 PM
Northside's Avatar
Northside
Originally Posted by gsxrboy96
For some reason or another, when you pay 20k for a bike, harleys quality control is pathetic and anemic to say the least, Harley has had a problem with lifters since the evo days, and still continue to this day, I wouldnt dare use another hd lifter, i would look elsewhere, vthunder,jims, so the answer to your question is no, your oil probably had nothing to with it, you should be asking the dealer why you paid 20k or more for a bike, that needs the engine serviced at 25k miles, and i dont understand why people are openly "ok" with this, Think about it, if your chevy truck needed the lifters replaced every25k miles, youd be calling the bbb and anyone else who would lend a ear, its bullshit, and if had a new bike that ran hot, rattled lifters, shifted cranks, Id ride that bike right up harleys ***...sorry...end of rant....
I believe they are the same lifters small block Chevys use. While Evos had problems with the rollers, the Twin Cams have been upgraded to better rollers on the lifters. A lot of us think the stock lifters in the Twin Cam are better than the aftermarket products, and I run them on fairly radical cams. A bud put JIMS in his hot rod twin cam and they were noisy right off, he replaced them with his old lifterrs and they are quiet with 56,000 miles.
Old Jan 31, 2010 | 11:15 PM
Mike's Avatar
Mike
Anybody try Crane 10530 lifters? They've shown up in a couple of threads as being a drop in replacement for tc motors.
Old Feb 1, 2010 | 07:17 AM
gsxrboy96's Avatar
gsxrboy96
Thats a common misconception, they are not the same as chevy lifters, plus chevy lifters have been known to last 175k miles in a car, and obviously, you stock lifters are NOT ANY BETTER then jims if they are failing, Listen, are they going to be noisy, of course, you have a air cooled engine with, imo a radical angle of valve train, Im not saying that you wont get vt noise, but you should not have lifters FAILING, period, and its not ok to make excuses for them, if it were my buck, id want that **** warrantied with a quality product so it doenst happen again.
Old Feb 1, 2010 | 07:43 AM
Jinks's Avatar
Jinks
I'm curious, did you get your hands on the "failed" lifters? What failed? Were they not pumping up, or were the rollers loose? Early Evo lifters with the small axle had a life expectancy of around 35000 or so although I've seen 'em go much longer. The angle of the front exhaust lifter on Evo's was part of the problem, supposedly solved by the twin cam motor. The change to better angles in the twin cam motor & big axle lifters should increase lifter life. I'd want to see any that failed if it were in my motor.....
Old Feb 1, 2010 | 09:40 PM
Northside's Avatar
Northside
I didn't say my lifters failed. My bud's lifters didn't fail either. He listens to a wrench who has funny ideas, and bit on the JIMS lifters. He said they were noisy from the get go, and reinstalled his stock ones with 56,000 miles. I don't know anybody who had Twin cam lifter fail. Small block Chevy lifters sure look and measure the same. The internals could be different I don't know as my lifters have never failed, and I ride two modified Twin Cams with stock lifters, not the Screamin' Eagle which are known to be problematic. Glad to learn I have an air cooled engine and it's noisy. Thanks.
Old Feb 2, 2010 | 08:02 AM
huffhuff's Avatar
huffhuff
lifters in my 01 had over 50K on them when i went to gear drive. used Mobil 1 15W50 since first oil change at 500 miles and cams and lifters had no evidence of wear.
Old Feb 3, 2010 | 05:47 AM
gsxrboy96's Avatar
gsxrboy96
your lifters didnt fail, but appearantly there was just reason for the dealership to replace the author of the threads lifters, correct? and im on another forum where they have lifter problems in twikies, odd? aint it?
Not a problem, I didnt know if they were still handing out that poser hand book with all new twin cam purchases.
Old Feb 3, 2010 | 11:36 PM
Northside's Avatar
Northside
Just saying the circles I run in include a lot of guys with late model Harleys, some of the best wrenches in the area and some respected drag racers. Never been called poser before, that's funny. I have been rather well known in this part of the country for over thirty years and my experience is that the stock lifters are not a problem. Are there isolated incidents, of course if it's mechanical it will eventually fail. I don't know about other forums or what people do to cause problems. I just don't think it's fair to bad rap Harley on the twin cam lifters, if you were talking early Evo then I'd agree. I'm just talking from my experience and that of some pretty knowledgable guys.
Old Aug 28, 2010 | 10:19 PM
spgtti's Avatar
spgtti
If you continue to recommend the B lifter I suggest you do some more research.Here is a start-check out page 1 for picshttp://harleytechtalk.org/htt/index....,28042.20.html
Old Aug 28, 2010 | 11:44 PM
Northside's Avatar
Northside
Well you get your information from some guy posting on the net. I'll get mine from experience and the real world. It's pretty common knowledge that the Harley B lifter is hard to beat. Run whatever you want! I have 5 years and over 50,000 miles on Harley lifters on a Mackie 590 lift cam. I have buds who wrench daily and build Twin Cams on a regular basis. Most of them use the Harly B lifter, and don't like the S.E.
You do know that this is an old post?
