tour pack
Old Jun 12, 2006 | 12:28 AM
gaspare8's Avatar
gaspare8
6th Gear
Default tour pack
just finished takin off the tour pack on a 04 ultra ultrageezerglide was right it took me about 2 1/2 hours taking my time just order a badlander seat hope it has enought room under it for all the wires.
Old Jun 12, 2006 | 12:30 AM
RDKingRider's Avatar
RDKingRider
Default RE: tour pack
[sm=ttiwwp.gif]
Old Jun 12, 2006 | 12:48 AM
Peekaboo Bob's Avatar
Peekaboo Bob
Most of the wires you can coil up and tuck in the well by the battery. They all fit okay under the SE seat I put on mine.
Old Jun 12, 2006 | 12:52 AM
ccgobama's Avatar
ccgobama
here's mine
Old Jun 12, 2006 | 02:53 AM
kirtapp's Avatar
kirtapp
hey ccgobama ...
got the same thing and looking to do the same thing. Does your setup allow you to put your pack back on? Also, did you leave your cb mounted underneat?
Old Jun 12, 2006 | 11:25 AM
Wally's Avatar
Wally
Take the cable for the head set and run it out of the underseat cavity on the left, down and around the fuse box and back up and into the bike infront of the battery. I put mine there as I'll never use it. The other cables will coil up in the spaces around the battery as well. Get you're self a stubby flexible antenna from an auto parts store ($15 CDN) and mount it inside the fairing. Put the antenna cable from the tour pac in the underseat area first as you won't need it again either. Now if you get a tour pac docking set up, it's just the plugs for the speakers and the power feed fro the lights and CB antenna if you use it. I don't.
Old Jun 12, 2006 | 12:32 PM
Sleeps In Trees's Avatar
Sleeps In Trees
I wanted a QD tour-pak, but still have it fully functional (except CB, which I never use). I knew it had been done many times before, but searching the forums produced no tech-tips etc to help. I finally decided to do it myself, & found that it was actually pretty easy. Here's a link to instructions I wrote for ppl who were looking into doing the same mod. I hope it helps some:
Tour-pak QD wiring
Old Jun 12, 2006 | 12:36 PM
Sleeps In Trees
Hmmm, link doesn't seem to work, filter seems to be obscuring part of the address. Email me at: white1808@bellsouth.net & I'll send it.
hog dog 82
Apr 22, 2026 09:50 AM
Harrybeerbelly
Aug 14, 2018 03:19 PM
azmaniac
Audio Systems
Aug 7, 2018 01:35 PM
Wam
Feb 5, 2018 12:00 PM
reno55
Jun 28, 2017 02:28 PM
