Passing Lights
Old Sep 20, 2009 | 02:43 PM
rambler43's Avatar
rambler43
Default Passing Lights
i have an 07 ultra and would like to have the passing lites on with the high beam and off with low beam, anyone know how to do this?
Old Sep 20, 2009 | 03:30 PM
dawg's Avatar
dawg
There's several posts that contain the factory wiring diagram and the wiring modification diagram to make them come on with the high beams. If you want them to go off with the low beams you would need to modify the wiring scheme from that one that is posted and just wire the power feed directly into the high beam circuit.
Old Sep 20, 2009 | 04:27 PM
jlelliott's Avatar
jlelliott
This might help you out:
Old Sep 20, 2009 | 06:34 PM
spence222's Avatar
spence222
+1...I used this schematic and have had no issues in 3 years since doing so.
Old Sep 20, 2009 | 06:44 PM
Apex Rider's Avatar
Apex Rider
If you have,I do,a headlight modulator that works when the high beam is on --- how does the passing lamps work out with that wiring mode ?
Do the passing lamps stay on "steady" ? Any problems ?
HOG_0308
Apr 14, 2020 01:00 PM
ZenGlide
Jun 11, 2016 10:59 AM
Damion
May 14, 2012 10:36 PM
Dustmaker
Apr 12, 2012 05:02 PM
GatorbaitRKC
Sep 12, 2009 12:06 AM
