Another bering failure
Old Oct 5, 2009 | 07:09 PM
masterblaster's Avatar
masterblaster
Default Another bering failure
Took bike in for new rear tire today, when they were done they told me that the rear wheel bering failed. Asked them whats going on as my front bering failed at 10k miles when the replace the cupping front tire for free at the time I thought the vibes from the cupping tire damaged the front berings, they told me the berings were changed a few years ago to a sealed bering and they suck, they replace many under warranty.
The ? for the HDF brain trust? Is there a better bering for these wheels, Timken or something?
Old Oct 5, 2009 | 08:05 PM
xxxflhrci's Avatar
xxxflhrci
Never replaced the bearings in my 2000 model, the first year for the sealed bearings.
Old Oct 5, 2009 | 08:11 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Too much torque! LOL! Stay off the throttle.
Old Oct 5, 2009 | 08:15 PM
masterblaster
Funny the service tech had same comment hehe.
Old Oct 5, 2009 | 08:34 PM
UltraKla$$ic
Talking Is this you?
Tests have shown this is bad for rear wheel bearings.
Old Oct 5, 2009 | 08:53 PM
Chaos's Avatar
Chaos
I was wondering the same thing just today as I just dropped mine off for probably the same thing at 2000 miles. I am hearing a roar when I hit the brakes. Beginnings of a tank slapper at 85. It might be worth looking in to Timken ect to see if they do make something, as this is BS with a capital B and a capital S. Good grief that could get somebody killed.
Old Oct 5, 2009 | 09:16 PM
dFREDb's Avatar
dFREDb
Had my rear bearing go out at about 18,000 miles. They replaced it under warranty, but scary experience as I had little warning. When I left a light or stop sign and turned, I heard a "click" and the bike seemed to shift very slightly at the rear wheel. Stopped by the dealer the next morning on the way to work, and saw the spacer flanged out from the loose bearing rubbing against it. Left the bike there and called for a ride. Very dangerous situation that could have had a very unhappy ending. Thank God I ride often enough to notice even the slightest deviation from normal! Hope they come up with a better bearing real soon!
Old May 29, 2010 | 07:01 AM
masterblaster
Well took the bike in for the 25k and had them change tires, front under warranty rear just to get fresh rubber for the Hoka Hey challenge. Yep the berings bad again. What Timkin bering replaces the 09 stock bering?
Old May 29, 2010 | 07:19 AM
1flhtk4me's Avatar
1flhtk4me
What brand are the bearings that HD uses?
There may be other brand name replacements available thru a bearing distributor.
Old May 29, 2010 | 09:13 AM
tenn.vol.'s Avatar
tenn.vol.
Not hard to believe that HD cheeped out, AGAIN! When someone comes up with
the Timken # I will shotgun them when I install new tires. Tenn.Vol.
