Header Pipes Install
Old Oct 23, 2009 | 05:25 PM
Cheeze's Avatar
Cheeze
Default Header Pipes Install
I should be getting my V&H Dresser Duals soon for my 2010 Road Glide. Was wondering if I should install them myself or just let the dealer install them. I have never done this before and was wondering if anyone had any advice on the installation. How difficult is it to do on a scale from 1 to 10....10 being the hardest. Any tips or advice will be appreciated.
Old Oct 23, 2009 | 05:40 PM
powerglyde's Avatar
powerglyde
6th Gear
I put the dresser duals on my 09 SG...fairly easy job. V&H includes pretty good instructions.
Old Oct 23, 2009 | 05:43 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Do it yourself. Save the cash for the next mod.
Old Oct 23, 2009 | 06:18 PM
navyman's Avatar
navyman
Take your time and read the instructions several times prior to starting. One tip that really helped me: If you replace the exhaust gaskets in the heads, soak them with WD-40 before you attempt pushing them into the exhaust port. They will go in much easier.
Old Oct 23, 2009 | 07:19 PM
kmvallee's Avatar
kmvallee
Question
If you have to ask you might want to take it to the dealer! Sounds like you might be a little apprehensive.
Old Oct 23, 2009 | 08:21 PM
Cheeze's Avatar
Cheeze
I changed out the handlebars myself and put some Heritage bars on without any problems....rather simple actually just time consuming. I just like to know what im getting into before i start on something. Just didnt know if changing out header pipes was a PIA or not. But thanks for the feedback.
Old Oct 23, 2009 | 08:26 PM
VTwin-Goodies
Former Sponsor
Going to have to try this next time.
Old Oct 23, 2009 | 09:55 PM
Gunfighter13's Avatar
Gunfighter13
I would say it is a 5.
Old Oct 23, 2009 | 10:37 PM
Hrlyrider's Avatar
Hrlyrider
it is easier than changing bars, hardest thing is to get the old exhaust pipes apart. for me the right side I could put the heat shield on after the pipe was on. The lsft side had to have the heat shield on before the pipe was put on. I had one O2 sensor that must of been cross threaded and I could not get it out so just bought a new one, the other one came right out put antisieze on them when installing and do not get any on the sensor just the threads.
Old Oct 23, 2009 | 10:57 PM
marcparnes's Avatar
marcparnes
Where were you yesterday? Getting those damn things in without tearing them up was a PITA. By far the most difficult part. I sure could have used this tip! As it is I might have ended up with a small leak at the rear cylinder. I'm not sure but if I listen with a hose stuck in my ear and the other end by the port I think I can hear it popping. Time will tell
Marc
