'07 RK dying at idle
'07 RK, stage I with Rinehart S/O's, BS, and SERT, 17k miles. It's been dyno tuned twice, once when the original stage I was done and then recently when I was trying to fix this problem.
The engine light is not coming on so the dealer says there are no codes to read.
It ONLY happens after I've been on a trip for 1.5 hours. Then it may start by idleing high for a bit then say when I come to a redlight and have to pull in the clutch and apply both brakes it will go down to zero idle. Once I crank it back up it idles so low that I have to rev it to keep it running.
Stopped on the road the first time it happened and the service manager at a HD dealer said I was running too lean at idle so I had it retuned and richened up.
If and when I park the bike for an hour or so it will go back to running right.
Does anyone have any insight to this problem?
Thanks
Thanks
Also sounds like an ongoing problem.
I took it to the dealership when it started stalling on me when idling. At the time, I did not have the foggiest idea what was causing the problem. I got the impression from the service technicians that they had seen this occur before with the intake manifold seal.
forestfarm
09-04-2020 06:30 PM
