07 SG dieing at idle...
Old Aug 24, 2009 | 12:21 PM
ICIBUY's Avatar
ICIBUY
Default 07 SG dieing at idle...
My 07 SG is all of a sudden dieing on me... I will be driving down the highway and when I have to eventually stop... the idle will get a little rough and then die... I hit the buton and it starts right back up and idle's fine until I get going again and then when I stop it does it again... it did this about 5 times on Saturday... it is stock except air cleaner, true duals, and H-D download... only has 7K miles on it... think it needs a PowerCommander and a good dyno tune? Could it be bad gas? Please help if you can... Thanks!
Old Aug 24, 2009 | 04:37 PM
iclick's Avatar
iclick
There was a thread on this issue not long ago but I can't find it. An SB was provided by Dawg in a PDF file, however, and I saved it--so if you'll email me I'll send it to you.
Old Aug 24, 2009 | 04:44 PM
will2002's Avatar
will2002
Enging temperature sensor may be bad. Had that same thing happen on my '97 & '02 Ultras!----- New sensor was the fix for them.
Old Aug 24, 2009 | 06:12 PM
S&RSGLIDE07's Avatar
S&RSGLIDE07
There was another thread on here also. I had the same problem and it ended up being the idle set screw. It looked like it never had locktite on it from the factory. It was messed up too. I took it out and put a new screw in, set the butterfly and have not had a problem since. The only deference is sometimes I would also have a high idle. Either problem I could restart the bike and it seemed to go away for a few miles.
Old Aug 24, 2009 | 09:54 PM
genedjr's Avatar
genedjr
+1 on engine temp sensor or O2 sensor - both feeding bad crap will screw with idle.
...gene
iclick
Jul 15, 2022 05:30 PM
pmblackhawk
Feb 23, 2014 05:19 PM
Snort
Nov 23, 2009 03:20 AM
puma
Jun 13, 2009 07:49 PM
skratch
Jun 3, 2009 03:03 PM
