If it is too tight it will leak. Just loosen up the screws a bit until the gasket does not look smushed. If it still leaks get a new gasket. On the brake fluid reservoir it is always less tight than thought it should be.
Be sure there is no brake fluid between the gasket and cap, it will leak and you will think it a gasket and go buy another at $20. I did this after laying the cap upside down and got fluid between cap and gasket.
Like someone said dont squish the gasket when tightening, even 1 NM or 8 in lbs seems like too much, snug it tight w/o crushing the gasket and you will be ok, unless you overfilled it, and iff you have a RG it will stain the plastic
