I can't decide on what air cleaner to get. I would like to keep the nostalic harley cover. So do i just replace the filter and get the K&N filter, get the expensive K&N filter assembly, or get something completely different? is there that much of a difference between the K&N filter compared to the stage 1 set ups?
I don't know anything about Stage 1 but every vehicle I've owned has been fitted with a new K&N filter as soon as I get it home including my '08 1200. It works fine and I still have my stock cover on.
My Se ac came with a paper element. I went with the fiberglass high flow filter. It is cleanable but you use no oil. When I ordered my pcv I also ordered the K&N filter. I just like K&N filters. Your money, your choice
I am not crazy about the K&N the problem is you gotta keep them oiled if they run a little dry you can throw a baseball through em. Too much oil and the engine wont breathe right, the S/E air filter flows better than stock and its reusable. The bottom line is you cant have everything the best flowing aircleaner will allow more dirt into the engine which is not good, and the best filtering aircleaner will be more restrictive, I like the S/E its a nice blend of both.
If you are trying to increase air flow to the point of possibly increasing the leanness of your air/fuel mixture, there is no comparison in the greater volume of an air cleaner kit over the smaller volume of just an air filter - whether it's a K&N or any other brand.
The Fuel Moto and K&N air cleaner kits allow you to still use your stock Harley air filter cover.
When I have decided against an air cleaner kit on previous bikes, I still preferred a K&N air filter over the stock air filter for a little extra umph.
check out the SE Ventilator. Pretty cool looking. As Fireaxxe said if the K&N are not maintained properly with the proper amount of cleanliness and oil it could hinder performance and or allow larger particles through than a conventional filter. most folks run those K&N's till their mechanic recommends to clean it. It should be done much more frequently and prior to any substanial residue build up. Seen many a diesel truck with a "dusted" turbo from running a poorly maintained or dry K&N filter.
JMO but there's nothing nostalgic about the newer football shaped air cleaner. It's the first thing I changed on my bikes. A round or S&S style tear drop would more truly define a "nostalgic" look. The SE or Ness Big Sucker flow more air and there are nostalgic round covers for these. By all means use a K&N filter - their reputation speaks for itself. I have two K&N elements so there's always a clean one ready when it comes time for service (about every other oil change).
I had poor luck using the no-oil element from HD (holes) so it went in the trash and a K&N went back in it's place.
