HELP with adjustable pushrods!
Old Feb 18, 2010 | 07:56 PM
Hog Yild's Avatar
Hog Yild
I have the SE adjustable tapered one, 24tpi, 2.5 turns. Maybe this will help. When I tightened mine I used three wenches. One to hold the top pushrod, one to tighten the jam nut and the third to hold the lower part of the pushrod. Sure way of making sure the jam is snug on both.
Old Feb 18, 2010 | 08:43 PM
cuda67bnl's Avatar
cuda67bnl
Finished installing my Wood 6 cam today, with SE tapered rods. Went 3 turns on them, and locked them down. No noise what so ever, and no louder than the stockers were. So far anyways.......
Old Feb 19, 2010 | 03:00 PM
DeputyMike's Avatar
DeputyMike
Originally Posted by rbabos
I think you need to start over. While many use the tdc method, it must be actually tdc-compression to do it. To make life easier do this. Put the cyl you want to adjust on it's compression stroke. It will blow your finger off the plug hole as it's coming up. Put the piston at it's highest point.
You can at this point loosen and adjust both.
Lengthen the pushrod until all (vertical) play in the pushrod is taken up and from there extend the pushrod length the required turns per instructions. Tighten jam nut and repeat the other pushrod the same way.
Before rotating the engine make sure the lifters have bled down. This will be seen by being able to easily rotate the pushrods.
Set the other cylinder on the top of it's compression stroke and repeat the same process.
The other method some use is to rotate engine until the exhaust valve just starts to open by (viewing the pushrod) the intake pushrod is now adjusted. Let it bleed down and rotate engine until intake starts to open. Now adjust the exhaust pushrod. Let it bleed down and do the same with the other cylinder.
Don't use loctite.
Ron
Thanks Ron!
Old Feb 19, 2010 | 06:58 PM
Hog Yild's Avatar
Hog Yild
Or use a dial indicator and indicate each one to the lowest position, adjust the rod, lock it and go on to the next. Leaving time of course for the lift to bleed down before rotating the motor.
Old Feb 19, 2010 | 07:53 PM
MACHD03's Avatar
MACHD03
Originally Posted by DeputyMike
Yesterday I bragged, obviously prematurely, about my completed Stage I install, including the Woods cam and adjustable pushrods....
I need some guidance or suggestions...On my first attempt earlier this week, I started the bike and could hear a ticking sound coming from the right side of the engine near the pushrods. I called Jamie, and after opening them up again, found two of the jam nuts loose. I readjusted all four pushrods and cinched down (I thought!!) the jam nuts, and started it up...ALL QUIET! I was ecstatic, and could hardly wait to test drive it....
So, tonight the rain stopped and I jumped on the bike and took her out. Could feel a tremendous power increase, but then realized I could hear the ticking noise again! Q%^&*&^%$#@!#$%^&%$%^&*()(*&^%$..........Got back to my garage, and yes, the damn ticking has returned!!
What the hell am I doing wrong?!?? I haven't taken the covers off the pushrods again, that will have to wait till tomorrow, but I losing my freakin' mind!! PLEASE HELP!
Search the site, I know the andrews adjustable pushrods that Jaime sends out in the kit tells you what to adjust them to. But a search on the site, states Bob Wood suggests going 4.5 turns. That is what I have done on mine and no problems
Mac
Old Feb 19, 2010 | 08:18 PM
mtclassic's Avatar
mtclassic
no offense but some bad advice. Do not freaking be an animal when tightening the jam nuts as they can break and you can distort the threads making adjustment very difficult the next time as can using locktite.
are you sure it is not a bad lifter or rocker arm making contact in the rocker boxes. It does take but a spec of dirt to cause the lifter to act up.
Old Feb 20, 2010 | 06:20 AM
rodeking's Avatar
rodeking
I broke a lock nut on my SE adjustables when I was removing it to put on my TP rocker boxes. I got the ticking out of my engine with the TP boxes, shimming the rockers, and if using stock boxes use the tapered bolts to insure proper alignment.
crazytown
Engine Mechanical Topics
22
Apr 18, 2016 11:41 AM
SmittyFXDL
May 17, 2014 02:48 PM
D1gger
EVO
34
Mar 6, 2013 06:45 PM
96roadking
EVO
13
May 22, 2010 12:14 PM
flhtupser
Exhaust System Topics
Mar 23, 2009 03:58 PM
